Results 1 to 10 of 12
Thread: Sep 2017, Release Candidate 3
    Default Sep 2017, Release Candidate 3
    Please download and install both the V7.5 and V8 software packages.
    Download EFILive V7.5
    Download EFILive V8
    Release Candidate Version
    This RC3 version may now be used by all EFILive tuners and their customers in production environments.
    Barring any serious problems being discovered, this RC3 will become the official public download.
    If you do discover a problem with this RC3 software, please report it to EFILive as soon as possible by posting in this thread or by emailing support@efilive.com or by logging a support request in the helpdesk.
    Release Notes:
    PLEASE read the "Important Changes" section at the top of the "What's New" document.
    The way EFILive reports/uses software version numbers has changed (new in RC2).
    The way EFILive reports and manages out of range calibrations has changed (new in RC1).
    Version Numbers:
    After installing this beta release you should have the following software, boot block, firmware versions installed:
    • EFILive V7 software: V7.5.12 To view the installed version, select Help->About (in the V7 Scan or Tune software).
    • EFILive V8 software: V8.2.7 To view the installed version, select Help->About (in the V8 Scan and Tune software).
    • Boot Block: V2.07.007 (Feb 07, 2014) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
    • Firmware: V2.07.125 (Sep 28, 2017) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
    Known Issues:
    Issue #1:
    Workaround:
    None.
    It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available and fully integrated with the V8 tuning tool software.
    Issue #2:
    When logging DMA PIDs (i.e. PIDs whose names end with "_M" or "_DMA"), if the ignition is switched off for an extended period while data logging but data logging is not terminated, then when the ignition is switched on again the data log automatically continues. However the DMA PIDs may no longer return valid data.
    Workaround:
    EFILive recommends stopping the data log and restarting the data log when switching off the ignition for extended periods.
    Dec 2005
    So far for these OS's I've found the following tables do not have any description.
    12656286
    12655493
    12663404
    {B1518} B1518 - no caption yet
    {B1519} B1519 - no caption yet
    {B1511} B1511 - no caption yet
    {B1512} B1512 - no caption yet
    04.5 2500HD LLY EC/LB
    14 Sonic RS Sedan
    GM Certified Technician
    President of the 'I killed an ECM' club
    Jan 2006
    Default Lb7 Baro changes
    Something happen to the LB7 Baro stuff? The MAF injection timing tables are limited to 32 now? Not really important I don't use that anyways but just curious.
    04 LB7
    2010 LMM
    2015 LML
    Quote Originally Posted by rcr1978 View Post
    It appears to be a rounding error between EFILive limit and the ECM limit. They should both be the same value but the EFILive limit is slightly lower than the ECM limit.
    If you increase the display precision you can see the discrepancy, investigating...
    Diesel Forum Support Site Admin
    Nov 2005
    Quote Originally Posted by a78turbo View Post
    12656286
    12655493
    12663404
    The developer has reviewed the calz files and fixed them. (NOTE: It affected more than just the 3 OS's you listed). Please download and extract to the C:\Program Files (x86)\EFILive\V7.5\Calibrations\E78 folder.
    It would be appreciated if you could please let us know how you go before updating the next build.
    Cheers
    Cindy
    Paul,
    I found this, I drew a red box around it:
    Paul,
    If you make the window's width narrower, the "hint text" becomes visible. The four entry fields are incorrectly anchored to the right edge of the window which causes them to stretch as the window width is expanded, thus obscuring the "hint text". I'll "un-anchor" them in the next release.
    ok, thanks.
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Paul...
    Not sure if it even remotely related, I noticed this in the post you made....
    Issue #2:
    Workaround:
    After spending over a week logging E92s, I'm still not confident it's working correctly with respect to the commanded fuel pids and the BenFactor pids. (I'm using RC2 and not 3 yet)
    Having finally finished up the 2017 E92 job I was having the problems with, I switched to a friend's E67 car and noticed that everything as normal EXCEPT FOR THE E67 Ben Factor.
    I tried 3 different pid sets I had used in the past and they all return the same strange numbers which are not consistent with the AFR #s I'm seeing from the wideband.
    Realizing that Joe C and I had changed calc_pids.txt a few times, I tried each one going backwards until I got to the one I have been using for years with still no luck.
    Not sure if it's even slightly, remotely related, but I might go to work tomorrow and try my old reliable E38 configurations on a simple bolt on car.
    I saw you mention that the DMA type pids might get strange results, and I had to ask.
    In either case, is there anyone else out there having trouble with Commanded fuel type pids or ben factor pids lately??
    It's got me crippled at the moment.....
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
    Dec 2005
    So far this is working good. I knew what the descriptions should be, but it is confusing for some newer persons. Thank you for updating this issue.
    Quote Originally Posted by cindy@efilive View Post
    Cheers
    Cindy
    14 Sonic RS Sedan
  1. Sep 2017, Release Candidate 2
    Last Post: September 29th, 2017, 08:11 AM
  2. Sep 2017, Release Candidate 1
    Last Post: September 16th, 2017, 04:28 PM
  3. Sep 2015: EFILive Public Pre-Release
    Last Post: October 28th, 2015, 09:24 PM
  4. Known issues with Sep 12, 2014 release of the EFILive software and firmware.
    Last Post: September 26th, 2014, 04:43 AM
