Results 1 to 2 of 2
Thread: Question re: Controller Authorization
    Jul 2018
    Default Question re: Controller Authorization
    re: the following for a 2018 Chevy Cruze
    "To obtain the seed file for your vehicle, follow the procedure below:
    1. Attempt to read the controller to obtain the unauthorized auth-code. Because the authorized auth-code is not yet known, reading will fail with the error message:
    Is step 1 supposed to occur by plugging the EFI live controller into the OBD port while in the car or is it supposed to occur within the software interface where the software attempts to query a file on the disk?
ID:	22304   Click image for larger version.
ID:	22305   Click image for larger version.
ID:	22306   Click image for larger version.
    Yes, you need to plug your FlashScan into the OBDII port, turn key to the "key on engine off", then attempt to read the controller using V8 Scan & Tune. It will import unauthorized auth code into the F3->F8 Authorization area.
    If you are using an AutoCal, you can also try reading the controller using your AutoCal, then synchronizing it with V8 S&T to import the unauthorized auth-code. If that doesnt work, you will need to contact your tuner.
  1. Replies: 3
    Last Post: February 23rd, 2017, 04:33 PM
  2. May be a dumb question. Allison 5 speed controller
    By Cyrperformance in forum Allison 5 & 6 Speed
    Last Post: December 15th, 2016, 05:18 AM
  3. Controller Authorization
    By Chevy366 in forum Lounge
    Last Post: October 3rd, 2016, 05:36 AM
  4. Vortec PCM/Controller not listed under DVT controller selection.
    By Scatfish in forum Vortec V6/V8 Specific
    Last Post: April 5th, 2015, 12:10 PM
  5. Authorization has been set to Demo
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2009, 04:57 PM
