Results 1 to 4 of 4
Thread: 8l90e tutd
    Feb 2008
    Default 8l90e tutd
    I'm setting up an 8L90E behind a 2016 LT1 in an older car. I would like to get the TUTD function to work. I have read other post saying that the hard wire input goes to pin 39 on the T87 controller. I have the resistor values figured out. Is there something in the TCM that needs to be switched? I have looked and don't see anything in the cal that says something like "switch TUTD from serial to hard wire".
    Thanks in advance.
    TUTD is a hardwired connection since CAN/serial might get busy and slow down.
    Feb 2008
    There is no "switch" in the tune file to change from serial to hard wire. Is there anyway to get this added to the cal file?
    Probably not sorry, too hard to locate with these TCM's.
  1. Tutd tap shift 8l90e stand alone wirring diagram for gm connect and cruise
    By 04colyZQ8 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 26th, 2018, 02:44 PM
  2. 2015.5 GM 8l90e T87 controller R&D help
    By Dr. Oldsmobile in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 4th, 2017, 06:00 AM
  3. TUTD help needed please
    By Hooter in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 21st, 2014, 12:51 PM
  4. T42 tutd
    By HOWQUICK in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 19th, 2014, 06:34 PM
  5. T43 WOT Shifting TUTD
    By Highlander in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: May 13th, 2011, 03:35 PM
