Thread: looking for a 2017 cummins stock file
    Oct 2017
    Default looking for a 2017 cummins stock file
    operating system 52180100
    calibration id 32370831AD
    cummins ecm code D09066.03 BDC
    -thanks for the help!
    That is a CSP5 OS, the stock file would be OS 32180100.
    Try in here:
    https://forum.efilive.com/showthread.php?28187-2010-Cummins-stock-tune-library
    Oct 2017
    So i tried that exact tune with that os and put it on the truck I now have a service def system that comes on and off and a check engine light is on any ideas? though i maybe had the wrong os but apperently not
    Maybe it isn't the correct stock file for the truck.
    If you look at the ECM it will have printed on the label what the vehicle was originally built with (look at the 'E/C' code at the bottom). Have a look at see if it does say D09066.xx.
    Also, the OS you are trying to use is for a 2018 vehicle, a 2017 would be using an OS like 3217xxxx, not 3218xxxx.
    Oct 2017
    Alright ill look on the ecm and see what it says any harm in running a slighlty different stock file?
    Best to stick to what the truck came with or a later revision of what it came with.
    Eg if your CalID was:
    32370831AD
    You could run...
    32370831AD
    32370831AE
    32370831AF
    etc
  1. Cummins Stock file 2013-UP CM2350
    By GM-Josh in forum Cummins 6.7L
    Last Post: February 12th, 2018, 09:21 AM
  2. Locating a 2017 6.7L Cummins base file
    By jk1956383 in forum Cummins 6.7L
    Last Post: November 29th, 2017, 05:57 PM
  3. 2016 or 2017 Stock Z06 LT4 file??
    By Longslyde in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: August 15th, 2017, 06:54 AM
  4. need stock file for 2016 cummins
    By afrazier in forum Cummins 6.7L
    Last Post: December 29th, 2016, 07:13 AM
  5. Can not read 09 6.7L cummins stock file
    By FVPdiesel in forum Cummins 6.7L
    Last Post: March 15th, 2013, 10:54 AM
