Results 1 to 3 of 3
Thread: looking for base tune 2013 ram 2500 6.7 manual.
    Sep 2019
    Default looking for base tune 2013 ram 2500 6.7 manual.
    Tried all of the base tunes in the library. None seem to be right, i.e. loss of engine brake and turbo stuck at 50%. Any help would be greatly appreciated.
    Tim Zapoluch
    Every possible stock tune is available via links in this thread.
    https://forum.efilive.com/showthread...k-tune-library
    But you need to know what would have been in the ECM to begin with, if that is already been flashed over then you need to do this.
    Look at the label on the ECM and it should have printed on there an E/C number, it will look something like DO90002.20 , DO90007.16. You will find the files in the links have that in the name as well, match that up and you'll be good to go.
    Sep 2019
    I'll do that.. Thank you for your time.
    Tim Zapoluch
  1. I would like to beta test for the 2019 Ram 2500 6.7L Cummins.
    By CumminsTwang in forum Do you want to be a Beta Tester?
    Last Post: August 5th, 2019, 01:47 AM
  2. Replies: 3
    Last Post: August 16th, 2018, 09:47 AM
  3. E39 2011-2013 regal turbo 6spd manual tune help
    By Diesel122 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 12th, 2017, 04:18 AM
  4. RAM 2500 Cummins CM2200 U1601 DTC
    By cashbonus in forum Cummins 6.7L
    Last Post: September 15th, 2016, 08:19 AM
  5. EFI LIVE for stock 2010 dodge ram 2500
    By DODGE-2010 in forum Cummins 6.7L
    Last Post: September 7th, 2016, 07:39 AM
