Results 1 to 4 of 4
Thread: Disabling Active fuel Management
    Nov 2006
    Talking Disabling Active fuel Management
    Does anyone have a clue if the active fuel management can be disabled???
    Why you ask - it makes the cat back exhaust sound like crap!!
    I just want all 8 cylinders all the time like the old days.
    Thanks Robert
    Jan 2005
    Disabling shouldn't be a problem-- there are a number of tables that control DOD (the original name for active fuel management). I'm surprised sound is an issue- the DOD vehicles I've driven spend so little time in 4-cyl mode it seems like all DOD does is transition to DFCO. If you can't fgure out how to disable, send me a file.
    DigitalEFI- EFILive US Distributor
    Nov 2006
    Default Thanks!
    Before I changed the exhaust - you could not tell the change. Now that the exhaust is alittle deeper and louder, the change is very noticable.
    If you are in 8 cylinders, it sounds great.
    Jan 2004
    Check out the attachment Blacky posted in this thread. Should be as easy as hitting "Disable".
  1. Active Fuel Management controls?
    By XLR8NSS in forum General (Petrol, Gas, Ethanol)
    Last Post: January 20th, 2011, 09:39 AM
  2. Active Fuel Managment Strategies?
    By JAY4SPEED in forum Tuning For Economy
    Last Post: November 7th, 2009, 04:38 PM
  3. Replies: 2
    Last Post: December 19th, 2008, 08:58 PM
  4. Question about AFM (Active Fuel Management)
    By Hollis1 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2008, 02:30 PM
  5. Wiring for Active Fuel Management
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: May 5th, 2008, 09:28 PM
