Results 1 to 2 of 2
Thread: avg ltft and a/f plot
    May 2005
    Default avg ltft and a/f plot
    1-How can i get ltft avg per ftc so i can average ftc- thru 14.
    2-is thier a way to chart air/feul ratio aross rpm range--how?
    Create a map that mimics the LTFT matrix displayed by the Scan Tool (in menu option: "LS1/LS6->Longterm fuel trim cells" for your vehicle. See attached image for an example. I have also attached the MAP definition for the map shown in the image.
    You could log both banks individually, or you could create a calculated PID that averages both banks together and log the average in a single MAP.
    To map your AFR you will need a wide band O2 sensor.
  1. Ltft
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: October 11th, 2008, 10:44 PM
  2. How to plot a VE table
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: June 22nd, 2007, 12:54 PM
  3. ltft
    By zone in forum General (Petrol, Gas, Ethanol)
    Last Post: June 4th, 2006, 02:56 PM
  4. Help with LTFT please
    By bobfo in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2005, 12:38 AM
  5. Histogram Plot
    By Black02SS in forum General
    Last Post: May 27th, 2005, 11:43 PM
