O.K. for the LM-1 in the programmer in the top squares you input 5v at 0.75 Lambda. In the bottom you input 0v at 1.25 lamda & it will programme in with no problems. While this will limit the reading for boost it will be fine until I can work out a formula to get the full range.
I will be back with the pid shortly.
