Results 1 to 10 of 12
Thread: Upgrade to 7.5.1 worth it for LS1?
    Oct 2006
    Default Upgrade to 7.5.1 worth it for LS1?
    Does it make sense to upgrade to 7.5.1 from 7.3.3 if I'm only doing Gen III LS1 tuning using V1? E38/E67 stuff isn't going to do anything for me.
    It'd be worth it to me if there are significant upgrades in functionality, bugs eliminated, etc.
    Oct 2004
    I would probably wait for the full 7.5.x release to be posted. There are improvements to the software (logging performance etc) but nothing really specific to what you are primarily interested in.
    Andrew
    EFILive Crew
    Dec 2004
    I posted this in the general section... maybe I could have posted it here instead...
    Linear scaling/blending feature is missing in v7.4
    I've just upgraded from V7.31 to V7.42 and noticed the linear scaling and blending features are missing on the latest public release of the Tuning Tool (i.e. the icons are missing in V7.4.2).
    Has anyone else noticed the same?
    Oct 2004
    They are definitely there in the 7.5.1 pre-release.
    Andrew
    EFILive Crew
    Dec 2004
    Doh! Still can't see it in v7.5.1.
    What could have gone wrong?
    Oct 2004
    Not just moved has it?
    Andrew
    EFILive Crew
    Dec 2004
    Andrew
    I'm actually missing all the icons after the quadratic blending icon. That's the last eight icons in total that are missing from that toolbar.
    Btw, I uninstalled v7.3 and installed v7.4.2.
    EDIT: I've added a screenshot.
    Try this: instead of Maximize, do Restore on the window and manually size it to your display monitor, then close/reopen tunetool.
    Dec 2004
    Interesting suggestion, joecar. But the problem remains.
    I've had to improvise using MS Excel, meantime.
    Is there a common problem or does it only concern me? The only thing I haven't done is check the hash result (MD5) of the executable.
    Feb 2007
    Quote Originally Posted by SSbaby
    Those buttons are visible for me. Are you saying that you have the first six buttons on that toolbar but not the last eight? Is there anything to right of the "Quadratic" button? Did you try moving the toolbars around? (I'm assuming you already tried "Restore toolbars" from the View pulldown menu...)
    2004 Pontiac GTO - Quicksilver/red/m6
    1-of-344
  1. Worth the upgrade?
    By zapp168 in forum FlashScan V2
    Last Post: May 14th, 2008, 08:20 AM
  2. Is this Motron 60 information worth anything?
    By Redline Motorsports in forum Gen III V8 Specific
    Last Post: September 2nd, 2007, 04:31 AM
  3. Anyone know what 1kpa is worth at WOT?
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: January 29th, 2007, 06:16 AM
  4. Tuning a stock engine...Worth it?
    By CGTMS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2006, 10:21 AM
  5. Is SD worth it without the Custom OS?
    By FstBlkZ28 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 6th, 2006, 03:31 PM
