Results 1 to 10 of 11
Thread: Please Help Readings Gone Crazy
    Apr 2008
    Default Please Help Readings Gone Crazy
    Please Help I have read everything I possibly could but have no good results with this problem. Attached is a short log as you can see the readings on the dash are all maxed out and the LTFT's are ?The car was not reved passed 3000rpm. The display on the BBL shows correct data log is F-ed.Car is a 2002 LS1. Any thoughts or ideas? Thankx advance for the help.
    Nick M.
    Nick,
    Welcome to the forum...
    This log was taken with with V2 BBL, right...?
    If yes, you could do this:
    in the file Options.ini delete all lines containing WO2ST1 or WO2ST1; save file, then copy to V2 using EFILive Explorer;
    Or you could update to the latest BBL update (where it's fixed): showthread.php?t=7809
    If you do this, be sure to read thru that thread and read thru ReadMe_First.pdf and make sure you understand what it says.
    Joe
    P.S. you'll prpbably tell me that you already have the latest BBL update...
    Apr 2008
    Thankx for the info I will give it a try got my fingers crossed.
    Nick M,
    Default My options.ini file...
    Nick,
    Here's my Options.ini file (attached; remove the ".txt" from the end)...
    Save your Options.ini file, send it to me...
    then copy the attached Options.ini file to the Config Files tab on your V2 (using EFILive Explorer);
    go and log, and see what the uploaded log contains.
    The other thing to watch out for is to keep the channel count no bigger than 24;
    I checked my Options.ini file and that meets this criteria;
    I'm getting good logs from my 2001 LS1.
    Joe
    Apr 2008
    Thanks, after looking at your ini. file I was able to figure out was wrong with mine. Thankx a lot for your help.
    Nick M.
    Jul 2007
    What happens at > 24?
    07 Silverado DMax Classic
    Jun 2006
    Reading slows down, as only a maximum of 24 channels (bytes) can be transmitted per data frame ... therefore, the rate at which you receive information goes down ...
    Junior Member jomobco's Avatar
    Aug 2007
    This looks like the log I posted here:
    http://forum.efilive.com/showthread.php?t=8098
    What do you think Joe?
    Jomobco,
    His log: all pids have consistent incorrect values [and excessive bookmarks] (caused by early beta treating WO2ST1/WO2ST1 incorrectly);
    Your log: some pids have intermittent incorrect values;
    Oh, I see you logged 29 channels... if you logged using V2 BBL, then that couold be the problem... remove some pids to get the channel count to 24 or less (most pids take 1 channel, some take 2; see scantool PIDs tab for channel counts).
    Which V2 BBL revision are you using...?
    Joe
    Aug 2007
    bl 2.5.08 4/25/08 and fw 2.5.17 5/6/08
  1. Lc1 wrong readings.
    By tor1965 in forum General
    Last Post: May 4th, 2010, 10:47 AM
  2. What are your MAP readings?
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: April 19th, 2010, 08:48 PM
  3. MAP Readings in a 5.3 Vortec
    By RacerChris in forum Gen III V8 Specific
    Last Post: February 26th, 2009, 02:18 AM
  4. AFR readings low through EFI
    By Chalky in forum General
    Last Post: May 18th, 2006, 03:24 PM
  5. This is crazy!!
    By wait4me in forum Lounge
    Last Post: December 26th, 2005, 06:26 PM
