Results 1 to 10 of 10
Thread: Logging with Wideband
    Mar 2008
    Default Logging with Wideband
    Hey guys I have a Autometer wide band and I am needing help setting it up. EFI live isn't setup to be able to use this wide band. Can someone help me. I am new at this just trying to learn. Any help much appreciative.
    As per Autometer's web page, their wide band meter has a 0-4 volt output. You would need to find out what air fuel ratio is at what voltage. Then put the formula into EFI_Live calc_pids.txt.
    Al
    Mar 2008
    can anyone else help me with this? does anyone know the volt out put?
    Lifetime Member Rhino79's Avatar
    Jul 2006
    So based on autometers specs 0-4v and 10-20 afr should be a formula of:
    2.5*V+10 ??? And if so what would that pid look like??
    Mar 2008
    surely someone knows how to do this.
    2.5*V+10 is correct based on Rhino's post.
    See attached calc_pids.txt file.
    02SSLE,
    Take the calc_pids.txt file from post #6 and copy it to the folder: My Documents\EFILive\V7.5\User Configuration
    Joe
    Mar 2008
    Thanks joecar
    Mar 2008
    So I guess all I need to do now is hook up the two wires that I ran from the wideband to the V2 controller?
    Yes, connect:
    • signal wire to AD1+
    • signal return wire to AD1-
    Look on the decal on the back of your V2 to see which pins are AD1+/-.
    If you use AD1, then your pids are CALC.AFR_WB1 and CALC.BEN_WB1.
  1. Tutorial: FlashScan V2 Serial Wideband Logging
    By TAQuickness in forum Tutorials
    Last Post: July 22nd, 2015, 10:47 AM
  2. Wideband
    By pdasterly in forum Gen III V8 Specific
    Last Post: November 16th, 2008, 08:16 PM
  3. Which wideband O2?
    Last Post: May 4th, 2007, 11:10 AM
  4. PLX Wideband SM-AFR
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 22nd, 2006, 02:46 AM
  5. wideband way off with V2
    Last Post: December 10th, 2006, 09:13 AM
