Results 1 to 5 of 5
Thread: Just a few issues
    May 2008
    Default Just a few issues
    Hello I am new to EFI Live. My car is a 2002 Corvette M6 with a 408, ETP 215 heads, 230/242 601/612 115 LSA cam, 1 3/4 headers, and SLP underdrive pulley. So far I got the tune pretty much down as far as drivability but still am stumped over a few issues:
    1) Getting knock past 4400 rpm
    2) Car shakes hard under 1500 rpm if clutch is completely out (only rolling without pressing gas)
    3) Upon deceleration i.e. pushing in the clutch when coasting to a stop the rpms will drop to 700 before returning back to 900. I am trying to figure out how to keep this at a consistent 900.
    4) It takes a couple times and I have to press the accelerator pedal to start the car. It's not difficult to start but would rather be able to turn the key without any issues.
    I attached my current tune file.
    If someone could please help me with these. Not really looking for a done up tune from anyone but would rather learn how to take care of it myself. Thanks,
    Kevin
    Oct 2007
    I'm new to this myself still. So take my $.02 if you want.
    1, should be a no brainer. Change your 2 spark tables. I see your two tables are the same. From my understandings, one should be less then the other.
    2, sounds like throttle follower, or cracker? (I get them 2 confused)
    3, there are 2-3 different places this could be. B4603, B4522, B4332. Ive also read about people fuddging the timing tables down low to help with throttle recovery.
    4, I had to do that and my desired idle was off a bit. There is also a startup friction correction, and just flat startup correction. Maybe them. Also, are you "flooring" the peddle? Cause if so, that cuts fuel off and maybe your getting to much fuel?
    11 Silverado
    08 Sierra
    91 RS with 350 TPI and 411 ECM
    Lifetime Member jfpilla's Avatar
    Suggest you post a couple of scans. You can probably get some help.
    Run a scan in AM idling, from cold start to 92*c, in neutral with A/C off.
    Turn on the key and start the scan then start the car.
    Save without driving.
    Run a scan while driving after warmup
    The attached is a SS of suggested pids.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    May 2008
    Thanks guys I will try and get some logs posted.
    dixonk, welcome.
  1. What have the issues been with LMM'S?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 22nd, 2009, 02:06 PM
  2. A/C issues
    By Naf in forum Gen III V8 Specific
    Last Post: June 15th, 2009, 12:07 AM
  3. 2 bar E38 issues
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 1st, 2009, 03:51 AM
  4. KR log issues
    Last Post: October 3rd, 2008, 11:58 AM
  5. Ok some serious issues
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 05:45 AM
