Results 1 to 10 of 12
Thread: Scanner Not Tracking KPA in V VE tune table Correctly
    Lifetime Member MN C5's Avatar
    Mar 2005
    Default Scanner Not Tracking KPA in V VE tune table Correctly
    Ok, I'm trying to dial my VE in and the scanner is showing KPA at WOT of 95kpa. And in the tune on table B8101 the cell highlighted shows the correct RPM reference but only 29kpa which puts me in the wrong column.
    I'm using SAE.MAP and have a E38 ecm.
    You have to set the tunetool table to use the same units as the scantool's Data tab (tunetool seems to be using psi)...
    From scantool, goto PIDs tab and highlight MAP and go rightclick->metric.
    From tunetool, go Edit->Configure Display Units and select that table and do rightclick, and set col or row units to metric.
    More info (read down into each link):
    Jan 2007
    If only one system existed.....
    Quote Originally Posted by 2002_z28_six_speed View Post
    I thought about making Version 8 metric only - but then I thought about how many of our customers in the US have guns - so version 8 will still support two systems .
    However, it is being implemented a lot smarted in version 8.
    Jan 2007
    They've got Guns Paul....but they all think Australia is somewhere in Europe....so we're safe.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Im starting to get frusterated with the US Imperial system, I think its just "our" way of being the US of A and sticking it to every other country. But thats just me and I kinda wish everything was standardized, but my canadian friends switch between imperial and metric all the time for different things. Waaay confusing.
    Nov 2006
    it wouldn`t be such a problem if someone would fix the imperial units
    that have been off for over a year now.
    http://forum.efilive.com/showthread....ht=problem+7.4
    If it makes you US guys feel any better about staying imperial, of all the countries in the world you have Liberia and Burma on your side still, and.....well, that's it
    Sorry MrPrick, I try my best on the conversions as does Paul I am sure, but for me, the numbers mean nothing, I never got taught imperial at school, if you have specific problems please let us know.
    I thought Paul had been playing around with the PSI and Inches thing before this latest release.
    Oct 2006
    Must be someone from down under in the Firebird :
    http://www.youtube.com/watch?v=xHkNLmcRwy0
    In America (R) means Reverse not Race .
    2006 Trailblazer
    I changed that in the latest release. It now uses psi in both the scan tool and tuning tool. (Just don't right click on the MAP PID and select more info - I forgot to change the help text from inHg to psi)
  1. Replies: 14
    Last Post: June 20th, 2009, 04:48 AM
  2. Tuner not correctly following live scanner data?
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 06:30 AM
  3. B0729 table doesn't function correctly
    By lakingslayer in forum General (Diesel)
    Last Post: February 9th, 2008, 03:20 PM
  4. Replies: 4
    Last Post: January 6th, 2008, 11:47 AM
  5. Anyone have A0014 table working correctly with F.I.???
    Last Post: October 22nd, 2007, 05:02 AM
