Results 1 to 7 of 7
Thread: what`s the deal with Delphi 01D030B (42LB)?
    Nov 2006
    Default what`s the deal with Delphi 01D030B (42LB)?
    does anyone know how to get rid of the rich spots
    under deceleration with these injectors?
    i have tried all that i could think of,
    i found that if i change VE i get negative values and,
    still rich in certain areas.
    for me it is around the 50+kPa MAN.VAC range but not at all RPMs
    so it can`t be {B4001} IFR (i have tried)
    small pulse, minimum pulse, pulse width adjust and IFR,
    it does`nt seem to matter what i change or which way,
    i even tried someone else`s tables/values.
    Junior Member brokenfly's Avatar
    Mar 2007
    dfco???
    2004 A4 GTO OLSD 6.75@102.32mph 1/8th mile...
    http://www.youtube.com/watch?v=IB9sJ_W6QDY
    LS6 Factory Heads,Cam,Stall,N2O...
    Nov 2006
    Quote Originally Posted by brokenfly View Post
    dfco???
    nope.
    What is the smallest IBPW you see commanded...?
    Nov 2006
    i`ve kinda got them consistent, still needs work.
    i was hoping there was some kind of consensus on these injectors.
    LOL with the stock injectors i could not keep WOT (max kPa) steady,
    so i went with these.
    now its the low (below 30kPa) i see the over rich condition.
    here`s the first log shot of the VE table.
    i ended up being negative in the 30kPa and lower.
    Jan 2007
    I've fought this issue with my Bosch Greentops also.
    I believe the voltage offset (B3701) makes a difference....just haven't had time to play with it.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Nov 2006
    these things are a pain!
  1. Delphi connectors on LMM?
    By JoakimMD in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 24th, 2009, 05:02 AM
  2. Good Deal on Laptop
    By trailshredder in forum Duramax LB7
    Last Post: March 11th, 2009, 01:25 AM
  3. Whats this roadrunner pcm deal..??
    By WiseGuyZ06 in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 19th, 2007, 11:16 PM
  4. Delphi
    By GMPX in forum Lounge
    Last Post: October 9th, 2005, 10:54 AM
