Results 1 to 5 of 5
Thread: Trans not shifting at WOT
    Jan 2004
    Default Trans not shifting at WOT
    Hi,
    I have a 2002 Camaro 408 with a D1SC. The trans is a
    *** ( not FLT) level 4 4L60E transmission.
    Ever since the blower I can not get it to shift at WOT. No matter where I set the MPH or RPM it would rev to the limiter. When this happens, the scans shows PCM commanding the gear to shift...but it just revs to the limiter.
    The funny thing is when I removed the blower it shifts correctly.
    The vendor ask me to check the line pressure with the trans electrical connector off ( since that gives it full pressure) and it was fine with 250 psi. They told me the trans was fine and I needed a TCI trans controller to be able to shift it. They had experienced this with a customers car and this was what fixed it.
    Have anyone run across any problems similar to this?
    I am running EFIlive V1 commercial.
    Thanks,
    Andy
    Andy,
    In your tune file I see the following values:
    D0915 == 59 mph
    D0930 == 60 mph
    this could be why the WOT 2->3 shift doesn't trigger;
    set D0930 less than D0915 by at least 5 mph.
    BTW, your vehicle voltage is dropping to 12.4V... something may be wrong with your alternator.
    Regards,
    Joe
    Jan 2004
    Thanks Joe!
    Oct 2006
    Default Boucning off rev limiter before shifting
    DId that fix it? changing D0930 and D0915?
    Oct 2006
    All ears here; what was the outcome?
  1. trans not shifting propely
    By lb7/76camaro in forum Duramax LB7
    Last Post: June 27th, 2010, 12:41 PM
  2. 4x4 shifting
    By southern in forum Gen III V8 Specific
    Last Post: May 18th, 2010, 10:13 PM
  3. What is the difference between shifting VSS and RPM?
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2008, 05:34 PM
  4. 2-3 not shifting
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2007, 10:43 AM
  5. Shifting problem
    By driver456 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 26th, 2006, 11:33 AM
