hi all
i just bought new LC-1 with DB-Gage
the gage not same data in PC ??
see the video .
http://www.youtube.com/watch?v=lBVWWOMYUCU
and the EFI live scantools read 9.00 - 9.45 AFR_LC11
which one now th read correct AFR ??
hi all
see the video .
On the PC, is that LogWorks...?
Which pid are you using in the EFILive scantool...?
Are you connected to EXT.AD1...?
Are you using FlashScan V2...?
Is your LC-1 programmed to the default voltage->AFR translation...?
Is the LC-1 brown wire connected to AD1+...?
What LC-1 wire is connected to AD1-...?
1- yes
2- brown wire to the gage .
3 - AD1+ = yealow
AD1- = white
What are the programmed points on LC-1 channel 1 (yellow)...?
The "right" AFR will be on the LC-1's serial link, regardless of how it's programmed...
Have you seen the V2 BBL serial AFR feature that some people are using...?
Have a read thru these:
showthread.php?t=8741
showthread.php?t=8384
showthread.php?t=8115
Basically, V2 is able to read the serial comms bitstream from the LC-1 (and various other widebands) and obtain the AFR from this.
If your LC-1 is set to default, then brown wire (analog 2) matches the CALC.AFR_LC1x pids, and the yellow wire (analog 1) matches the NBO2 input.
