I performed a full flash with a stock operating system. I added my VIN number and then read the PCM. I changed the VE table and flashed cal changes. EFI required me to purchase another license which I did. That is another conversation.
This is where I am now. We replaced the cracked FAST intake due to GM valley cover bolts pushing on bottom of the aftermarket FAST intake. After correcting intake, car is idling correct and seems to be running better but needs a lot of adjusting to open loop.
After 15 seconds after start, I get flashing check engine light. Only P1689 and P1541 codes that are for traction control. I imagine that it is flashing MIL due to values from O2 sensors 1 bank 1 and 2. O2 sensors 2 bank 1 and 2 are removed.
Engine Information:
Largely ported and polished heads (243),
Cam has lift and dur. greater than 2006 Z06 specs.
hooks headers
Z06 injectors
383 CI
3" exhaust, no cats, no mufflers
I am attaching my tune file and logged data. I appreciate any advise on changing settings to correct.
Thanks!
