Results 1 to 6 of 6
Thread: options.txt file
    Jun 2008
    Default options.txt file
    Last week i updated to the newest version of 7.5 and 8 and the options.ini file has changed. i added in my PCU's like i had before in the old file and they worked fine, then i went to move all the duramax pids up to the top of the pid selection list like i had done in the old file and changed all the PSL_XX numbers to match to where i moved them to and now I get a message when i try to log "no pids selected". so the question is where do the PSL numbers come from? are they associated with the selection list in descending order?
    03 Silverado CCSB LT Summit White
    417rwhp / 898trq <-old numbers need time to get on the rollers again
    4" Straight Thru Exhaust, Suncoast IV W/ 1058, Amsoil everything, EFILive DSP5 tuned by me with some help from Nick, PPE lift pump, and a BD spinny thing
    May 2008
    Welcome to the forum!
    What version of firmware are you running on the flashscan?
    On mine, I had backup my old pid config directory, then go into the EFILive Explorer and run "format" on the config tab. Then select all of the .pid files and the options file and drag them down to the lower pane to copy them to the flashscan.
    Also, the options.ini has moved to options.txt
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Post your old options.ini file (first add .txt to the end of the filename).
    Jun 2008
    I got her fixed now i forgot to put the "0" in front of the single digit PSL numbers. after i starred at the damn thing for 2 hours. its always something small an stupid. Thanks for the offer to help and the welcome guys. - JB
    Edit: I do have another question though. anyone know if the pid names are different for the new BBL update, some of the DMA pids are showing up? oh and the bootblock and firmware are the latest versions.
    Oct 2004
    Have a look at the documents in the 'C:\Program Files\EFILive\V8\Documents\Pid Descriptions' folder. Generally the _DMA PIDs differ in that that they are change to _M.
    Andrew
    EFILive Crew
    Jun 2008
    Nice catch! Forgoet about that.
  1. Someone have a Custom Options File?
    By turboolds in forum FlashScan V2
    Last Post: June 16th, 2009, 02:30 PM
  2. Options ini
    By nchristian in forum Gen III V8 Specific
    Last Post: March 3rd, 2009, 07:57 AM
  3. New Options.txt
    By Cougar281 in forum FlashScan V2
    Last Post: October 22nd, 2008, 07:52 AM
  4. Red X On My Options..help??
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2006, 05:32 PM
  5. 98 PCM options
    By Techfan in forum Custom Operating Systems
    Last Post: March 23rd, 2006, 03:09 AM
