Cant find options ini on the efi exploxer. I have looked to both places for it in the efi exploxer. I even udated it last night. thanks for the help
look for options.txt
FLASHSCAN V2 & AUTOCAL
I found options txt. But where is options ini.i want to do bbl. And use a wideband 02
Options.ini has been replaced with Options.txt (due to Vista issues, from what I understand).
Which wideband will you be using...?
More info:
Updating FlashScan V2 Firmware:
showthread.php?t=9375 posts #9 and #10
showthread.php?t=10014
V2 serial/digital wideband logging:
showthread.php?t=8858
showthread.php?t=8115
V2 serial/digital AFR input (LC-1):
showthread.php?t=7532
showthread.php?t=8348
V2 serial/digital AFR input (PLX):
showthread.php?t=7726
Im looking at getting the lm 1
