I was dyno tuned a couple months ago but recently switched to AFR 225 heads to increase cr from 8:1 to 9:1 and adjusted the tune likewise. I had a buddy of mine check/retune and he said my VE and MAF were right on. The problem is that my LTFT's are at +25% and I keep getting a lean code for Banks 1 and 2. He told me to check to make sure my MAF was plugged in correctly(which should be since we did not unplug it) and to clean it. Also, to check my 02 sensors to see if they are plugged in correctly. I am going to but some MAF cleaner and spray the MAF just to make sure it is clean and plugged in correctly.
What could be causing my lean condition?
Also, I noticed that when logging if my tune file is also open I can see where I am at during driving as far as the Main VE table and/or Spark tables go but the Main VE table is not referencing the same Kpa as the log.
