Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Setting up V2 for BBL...
    Oct 2004
    You make some good points.
    Significantly the version 8 software is under heavy development right now, with it eventually superseding the current version 7 software. As it is undergoing constant change threads such as these do become obsolete, and serve to potentially provide no longer accurate information to users. For instance, it is no longer really necessary (in the main) to modify the Options.txt file manually. This activity is performed no through the version 8 Scan and Tune application.
    As we get closer to the complete release of version 8 there will clearly be documentation produced and updated tutorials.
    Andrew
    EFILive Crew
    Yes, EFILive will have an updated user manual... the software has been changing during this year, and the above are interim instructions...
    Until S&T came along, EE was the only way to program V2.
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Is this info still good for setting up V2 BBL? I need to set mine up.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    Quote Originally Posted by BowlingSS View Post
    Bill
    Hi Bill,
    That info is now old...
    See this: showthread.php?14757-November-18th-2010-pre-release
    You use EFILive Explorer to update new firmware.
    Then use Scan&Tune to configure Black Box Settings (pid lists) and Device Settings (wideband type and serial/digital pids) --> on each of those Windows make sure to click Program to write those to your V2.
    Apr 2011
    Is the above still good to program. Sorry newbie here
    No, that's old, some parts of it is still relevant, other parts have been replaced by V8 software.
    See the pics in these threads:
    Make sure you update your V7/V8 software from www.efilive.com/downloads.
  1. Help setting up LC1
    By Slow73 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 29th, 2009, 03:51 PM
  2. Help setting up AEM WB
    By SUPERTRUCKER in forum General (Petrol, Gas, Ethanol)
    Last Post: April 18th, 2009, 10:22 AM
  3. Setting up A0014
    Last Post: April 7th, 2008, 02:00 PM
  4. fan setting for ls2?
    By minytrker in forum Gen IV V8 Specific
    Last Post: June 15th, 2007, 03:45 AM
  5. Setting up PLX with V2
    By mtnman in forum FlashScan V2
    Last Post: February 8th, 2007, 07:20 AM
