Page 14 of 20 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 199
Thread: New Tuning Tutorial: WeathermanShawn
  1. #131
    Oct 2006
    This map does not have matching labels, this is why you can't paste w/labels.
    I thought "matching values" meant that the LTFTBEN table had to have the same row numeration as B5001 - which it does. Do you mean to say that since the data begins on the 8th row, that copy with labels won't carry over the first 7 blank rows - and so the table is misaligned, and doesn't have "matching values"?
    And here's a shot of the column set up, as that has been questioned ...
Name:	LTFTBEN Table II.jpg
  2. #132
    RevGTO, the column heading should say "Value" with an uppercase "V", same as table B5001 (your pic shows "value").
  3. #133
    Shawn, thanks for the kind words...
    I hope I did learn something 30 years ago and not just warm the bench at school...
  4. #134
    The differences between the new ones and the original ones:
    - VE[%]: the new one is about 1% less than the original.
    - VE[VE]: the new one is about 18% less than the original (and matches my existing B0101).
    My math is maybe not so good, which would explain the difference
  5. #135
    Oct 2006
    Ok, thanks. It's shown in lower case in the Tutorial, so if that's erroneous, correction needed there.
  6. #136
    Quote Originally Posted by RevGTO View Post
    Thanks. Noted. The tutorial will be updated.
  7. #137
    Jul 2008
    Thanks everybody for the feedback.
    I will try to post up a list of Tutorial Typos, updates, etc..
    It is always smarter to get them all corrected in one big update, but we realize people are using the Tutorial in its current form.
    Other than the necessary 'computer work', has this method of tuning made tuning easier or simpler? Any feedback on the actual tuning method itself?
    Thanks..
  8. #138
    Once you setup the maps it's pretty simple, one log gives pretty good results (with filtered out throttle transients, as said in the tutorial).
  9. #139
    Apr 2009
    Explains why I couldnt multiply with labels. Thanks. I'll try the new formula in the next two days.
  10. #140
    Jul 2008
    So far these are the Typographical errors noted with the Tutorial, or where clarification is needed.
    If anybody notes any others, please post them up.
    Thanks..
    ***Tuning Tutorial Changes:***
    Page 2: Update calc_pids.txt
    Provide Link to Text Thread?
    Page 6: Line 10. Last word value, should read Value.
    Page 7: Change Filter to Read SAE.ECT.C less than or equal to 80C
  1. How about a transmission tuning tutorial!
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 3rd, 2020, 04:53 AM
  2. Tuning Notes by WeathermanShawn
    Last Post: July 12th, 2013, 03:21 AM
  3. WeatherManShawn's Tutorial: can someone look/help...??
    By tatasta in forum Gen III V8 Specific
    Last Post: April 28th, 2010, 02:25 PM
  4. Idle tuning... more info on tutorial please!
    By vxleather in forum Tutorials
    Last Post: July 16th, 2008, 12:11 PM
  5. How about a transmission tuning tutorial!
    Last Post: August 5th, 2006, 04:09 AM
