Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 82
Thread: Chev/Holden 1.4L Cruze E85 FlexFuel Conversion
  1. #41
    The 24 channel limit on pass through, it's a v7.5 thing going back to the old LS1 PCM.
    Below is my V2 BBL config, 42 channels.
  2. #42
    Dec 2006
    I always use laptop, and I was having this issue even with much less than 24 PIDs. Will try BBL for the first time, and report.
    $2800 '02 Silverado RCSB 5.3 L59
    daily driver
    $3600 '05 Savana G3500 box truck 6.0 LQ4
    sleeper race truck project
  3. #43
    Dec 2006
    Also, are we using V8 for scanning now? Or just BBL? Because I was using V7 Scan Tool.
    daily driver
  4. #44
    Dec 2007
    Yes, I haven't used a laptop in my car for at least 1 year. It's been BBL since it was available.
    Well it looks like I'm out of the market for a Cruze as my wife picked the 328i and we love the crap out of it.. Long story short - she broke her neck in December, got a C5-C6 fusion and wanted a "Halo" car in celebration of her recovery.
    What sps rate are you getting with the 42 channels? I have always assumed it was a limitation of the chip in the hand-held and never tried more than 24 channels at a time. If I could get 10 sps or better for most PID's and run 50 it would be much better than swapping groups for different PID's when I stack it up with too many _M type.
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
  5. #45
    Dec 2006
    Ok thanks, so could you guys please link a topic that helps you set up BBL or just give some brief pointers? I will also look for this info now and try to do it in the meanwhile. Does it require an SD card?
    daily driver
  6. #46
    Nov 2005
    Quote Originally Posted by Boost View Post
    The Verano is a Cruze, with some nice Buick touches and big engines.
    Nice little article today on the Verano at GM Authority
    http://gmauthority.com/blog/2012/07/...ty-31-highway/
    Cindy
  7. #47
    Doesn't need an SD card, but they are sooo cheap and you can store sooo many log/tune files...
    you will need to run the V8 S&T program to configure the BBx (setup scan pidlists, setup tune ECM, setup DTC) and program it to your V2...
    but first download/install the latest V7 and V8 software from the EFILive downoads page, and flash in the latest bootblock/firmware, do that before configuring BBx.
  8. #48
    Dec 2006
    Thanks Joe and Cindy!!
    daily driver
  9. #49
    Jan 2009
    I have a 2005 HSV Grange and noticed the E80 tables in the tune. Is the flex fuel sensor a usable item with the e40 pcm?
  10. #50
    No, sorry, as far as I know FlexFuel was never finalised on any E40 applications.
  1. 05 Hummer/55 Chev conversion..
    By Chuck L. in forum Conversions / Aftermarket Parts
    Last Post: June 8th, 2011, 03:45 AM
  2. E85 Conversion
    By duramax2500hd in forum Petrol / Gas
    Last Post: June 15th, 2010, 01:12 PM
  3. L92/L76 AFM/FlexFuel
    By Cougar281 in forum Gen IV V8 Specific
    Last Post: April 21st, 2009, 10:38 AM
  4. L98 into LS1 Holden conversion
    By rally1 in forum Gen IV V8 Specific
    Last Post: September 10th, 2008, 01:58 AM
  5. Flexfuel - E85 - How does the ECM know?
    By gmh308 in forum Gen IV V8 Specific
    Last Post: February 16th, 2008, 03:59 PM
Tags for this Thread
