Page 10 of 16 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 156
Thread: How about a transmission tuning tutorial!
  1. #91
    Quote Originally Posted by mtnman
    Is there any way to adjust shift firmness during AutoVE tuning? My shifts are freakishly hard and jerky.
    Make sure that P0101, P0102, P0103 are disabled in these tables:
    E0101, E0102, E0103, E0104
    edit: and check for any instances of P0101, P0102, P0103 in any Exxxx tables.
    (they don't appear in all these tables)
  2. #92
    Let's play with the numbers...
    416 * 1.356 = 564
    416 / 1.356 = 307
    Hmmm... it would appear that EFILive is dividing instead of multiplying to get the torque numbers.
    Also "broken" is GM.TFMPRS (psi is ok, but kPa is wrong).
    Both will be fixed in the next release.
  3. #93
    Paul, thanks mate, excellent customer service.
  4. #94
    Quote Originally Posted by Flyer
    Joecar
    My car is changing gears nicely now - but the 2-3 change at lower 1/3 Nm values is a bit clunky - what can i do about it? My LSD/diff is a bit worn i think as well so it might be a factor.
    At high % its fine. But low down it is a little bit bangy rather than positive and quick like the 1-2 change.
    I have no torque management set at all and remember i have a SS3600 converter
    I experimented a little, and I found that I can eliminate the clunk most of the time if I revert back to stock the lower portion (TPS < 25%) of the PT 2-3 upshift table D0902 and the PT 3-2 downshift table D0907. It still happens, but less frequently and less pronounced when it does.
    I spend about 30 minutes/day in 0-25MPH stop/go conditions (freeway traffic jam) so I get good opportunities to test this out.
    So I don't know if your tables are modified, if they are you may want to try this.
  5. #95
    Well, thanks for the help you guys provided me without even knowing it. My 02 TrailBlazer with Transgo HD-2 shift searches for gears on the hwy and above about 45mph, but after reading this thread I have some ideas that I am going to try tomorrow and see what happens!!
  6. #96
    Quote Originally Posted by ScarabEpic22
    Let us know how it goes/went...
  7. #97
    Mar 2005
    Hi there guys.
    Did my first trans tune on a VYII Holden R8. Interesting experience with very good results!
    The trans had the usual clunky down shift and slow sloppy upshift under hard acceleration. It also had that annoying TTC lockup in 4th gear that won't unlock when you hit a decent hill unless you really stab the throttle or pass 50% TPS or more. This means you are always reaching for the manual change to 3rd or suffer in silence and slooooowwww down
    What amazed me was how different the car was to drive once we "got it right" !
    The Upshifts were snappy yet not jerky giving a performance feel, the downshifts on light throttle were almost imperseivable, the TTC was hardly noticible on lockup.
    And best of all, the moment you hit a hill and needed a bit more grunt the TTC unlocked at about 40% tps (standard about 52%) and away you went. The customer was very impressed and so was I.
    Thanks for all the good info and tuning tips on this thread !
    Mike
    "Just a tune > yeah right !!!! "
  8. #98
    Jul 2008
    Quote Originally Posted by The Alchemist View Post
    what exactly had an impact on this?
    thanks!
    forged LS1 I Patriot Stage III heads I Patrick G spec'd TR grind Comp Cam I ProCharger I High Tech Transmissions I Ultimate Converter Concepts I tuned by cablebandit (soon to be me) @ MSS I Exotic Exhaust & Fabrication custom exhaust
  9. #99
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    This is a old thread.....
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
  10. #100
    Mar 2005
    Quote Originally Posted by Superado View Post
    thanks!
    TCC unlock in 4th gear vs TPS...can't remember the "B" series number.
    Works a treat.
    Mike
  1. New Tuning Tutorial: WeathermanShawn
    By WeathermanShawn in forum Tutorials
    Last Post: March 1st, 2011, 09:31 AM
  2. Question on Tuning with AutoVE tutorial
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 1st, 2009, 03:35 AM
  3. How about a transmission tuning tutorial!
    Last Post: August 5th, 2006, 04:09 AM
  4. Simple yes or no...would you like a tuning tutorial for EFI Live?
    Last Post: July 22nd, 2006, 02:38 AM
  5. Tutorial for tuning VE using LTFT's using EFILive ??
    By Thedude in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2005, 10:55 AM
