Page 8 of 26 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 258
Thread: using 14.047 for desired AFR and not 14.63?
  1. #71
    Feb 2008
    LS7 GMPP Calibration Stoich Table
    E % __ AFR Stoich
    0 _____ 14.678223
    6.25 __ 14.322266
    12.5 __ 13.965820
    18.75 _ 13.609863
    25.00 _ 13.252930
    31.75 _ 12.896973
    37.50 _ 12.541016
    43.75 _ 12.184082
    50.00 _ 11.828125
    56.25 _ 11.472168
    62.50 _ 11.115234
    68.75 _ 10.758789
    75.00 _ 10.402832
    81.25 _ 10.046875
    87.50 _ 9.689941
    93.75 _ 9.333984
    100% _ 8.978027
    Cal Editor aka A.J.
    Lead Calibrator at PCM Calibrators
    ASE Master Certified since 1988 -- ASE L1, F1 & A9
    GM Technician since 1999 -- GM World Class Technician since 2009
    CNG Installer -- CSA Inspector
    A handful of people out there who do have an intimate knowledge of GM Calibrations
  2. #72
    Dec 2007
    Quote Originally Posted by CalEditor View Post
    E % __ AFR Stoich
    0 _____ 14.678223
    6.25 __ 14.322266
    12.5 __ 13.965820
    18.75 _ 13.609863
    25.00 _ 13.252930
    31.75 _ 12.896973
    37.50 _ 12.541016
    43.75 _ 12.184082
    50.00 _ 11.828125
    56.25 _ 11.472168
    62.50 _ 11.115234
    68.75 _ 10.758789
    75.00 _ 10.402832
    81.25 _ 10.046875
    87.50 _ 9.689941
    93.75 _ 9.333984
    100% _ 8.978027
    Gotta love the 6 SD accuracy of the calibration in these GM OS's.
  3. #73
    Nov 2006
    Quote Originally Posted by gmh308 View Post
    http://www.zeitronix.com/Products/ECA/ECA.htm
    If there is a table in the OS for stoich values, and you want to change it, simply change the first value - the 0% value. And optionally the second value. Why ? Have seen GM OS's (the ones with the tables) show the ethanol content as 3%, so setting the second value (6.25% ?) to your chosen stoichiometric AFR ensures that if there is some offset built (maybe as there is so much E in fuels these days) that it potentially has no influence.
    Some OS' have only one value.
    {B3601} (OS 12212156) is stuck to whatever you think you fuel will be.
    There is no way for the PCM to change EQ1 for % of Ethanol.
    I have read a few posts where some people have supposedly found away
    around this with the older OS' but they offered no details.
    LC-1 WBO2
  4. #74
    Dec 2007
    Correct. The stoich number needs to be changed in all of them to do this simply. The only OS's that use % ethanol are the flex fuel OS's with flex fuel enabled.
    EFILive imposed limit is 10:1, but it allows lower numbers it seems with a "red" border on the cell which I guess means "beware".
    Have made this stoich change on later OS's with positive results.
    Sorry I thought you meant you had the table in 12212156. Just took a look at that with its single stoich number.
  5. #75
    Feb 2008
    Understatement
    Look at the big picture. I use OSID 12611134 commonly and stoich is 14.569824 across the table. I am in a E10 area. Just correcting that makes the cars run better as if it was in an E0 area. Then do a like adjusting for the E10 in the EQ table and the PE table and WOW.
    Customers seem to be very happy with just these adjustments.
    Cal Editor aka A.J.
  6. #76
    Dec 2007
    Understatement
    Great to hear! Yes its is unforunate that GM chooses not to leverage the potential of E10 even in their flex fuel vehicles. Leaving E10 as for E0.
    What is 12611134 from?
  7. #77
    Feb 2008
    Northstar with a blower.
    If you knew me that would be a no brainer. I am one of the Northstar Guys, but I have started to step back from them and work with the other GM engines.
    I am sooooooooooooooooo much happier
    Cal Editor aka A.J.
  8. #78
    Lifetime Member 98 tigershark's Avatar
    Nov 2006
    Did you work with Dave Hill?
    98 tigershark
    L92/427 w/L76 CC'ed heads n upgraded springs
    4.100 stroke, 4.068 bore w/ 11:1 comp
    Cam, 591 int, 613exhst, [email protected], 115*
    LG headers, High flow cats,
    RPM level 5 trans, RPM 3.42 gears, 2800 rpm trq convrt. .
    Special Thanx to Joe and Bruce!
  9. #79
    Oct 2006
    http://www.holdencrazy.com/EFILive/ , L59 is Flex Fuel - B3101 , B3103 , B3601 , B3695 , B3701 , B4001 .
    COS3 or COS5 is easier .
    Doesn't EFI University teach this in their EFILive courses ?
    2006 Trailblazer
  10. #80
    Nov 2006
    Default Teach what?
    I am from the northwest mountains, R U maken funnys bout ma skoulen. I only learned to read and write a few years tago. I aint gonna go ta no skoul nohow noway, it tukma tree yeas ta learn ha ta go on da intranote. A unavarsity is a skouls write? Ah kinda like EFILive cause u can luk at da pretty pictures. Ah wish a could draw like dat, Den ah might gonna get me real rich. Like Mr Paul. mr.prick an mr.ross told ma dat mr paul was da owner of da intranote an I baleave dem dudes. whats holden crazy anaways? a pliace were ya hold crazzie thangs. I got ma a fu tuns from thare 1nc and I liked da nice pictures ta louk at. Da they call it download cuz its frum downunda? I culd go thare if in it was fa free. Ah noes bout alcohol cuz I live in da mountains. I caint baleave ya all dodnt knows bout makin alcohol an puttin it in a automobile, evens ah knows bout dat. Did ah tell ya I live in da mountains? Ah caint rememba.
    98 tigershark
    P.S. I am pretty tired. Thanks for the PIDS, only problem is I only have V1 7.5.3.
    Last edited by 98 tigershark; September 5th, 2009 at 05:53 PM. Reason: cant remember
    98 tigershark
  1. B0720-FRP: actual or desired?
    Last Post: November 11th, 2009, 05:55 AM
  2. Desired Airflow Map, not quite right, help
    By kwhiteside in forum Gen III V8 Specific
    Last Post: September 8th, 2009, 07:14 AM
  3. Desired Shift Time
    By A6sportsracer in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: June 27th, 2009, 11:45 AM
  4. How does desired boost work?
    By pistonrings in forum Duramax LLY
    Last Post: May 30th, 2009, 04:47 AM
  5. Desired Airflow
    By Thumper in forum Gen III V8 Specific
    Last Post: April 23rd, 2008, 02:23 AM
