Results 1 to 10 of 17
Thread: E38 Standalone harness ?'s
    Aug 2008
    Default E38 Standalone harness ?'s
    I finally got ahold of pinouts and schematics to make a standalone harness for a (E38) 2007 Silverado 5.3ltr**58 Tooth Reluctor & Electronic throttle... After looking over the pinouts, quite a few pin assignments refer to "LOW REFERENCE" Does that mean ground? Or? I don't want to proceed till I know what Low Reference is referring to...
Name:	Low Reference.png
    FLASHSCAN V2 & AUTOCAL
    They are all common grounds.
    You just need to connect to the 'big' ground pin, which is Pin 73 on the black plug.
    Aug 2008
    OK cool! Thanks Ross...
    Apr 2007
    the low references are for the sensors. You need to follow the circuit number back the the sensor otherwise it won't see the right low ref from the sensor and the computer will not be happy.
    P.S. Ross, I still haven't got this combo to work stand alone yet. I must be missing something.
    Senior Member doubledip's Avatar
    May 2008
    what doesnt work... what is the combo ?
    E38's got to love them
    E40's hate 'em
    LS1's is there anything it wont work on
    Holden VE SSV - GEN46L
    www.ultimateconversionwiring.com.au
    www.dualflash.com.au
    Nov 2006
    2007 6.0L Vette E38.zip
    Here are the pinouts for a Vette (E38)
    LC-1 WBO2
    Aug 2008
    Here are the pinouts for the 2007 Silverado E38 ECM & T42 TCM
    Aug 2008
    Here are the connector end views:
    ***Note the 3rd connector is the TCM connector end view***
Name:	X1 connector.gif
ID:	6314   Click image for larger version.
Name:	X2 connector.gif
ID:	6315   Click image for larger version.
    Apr 2007
    Ross,
    Do you know if there is a catch in the software that doesn't allow the injectors to be fired if no oil pressure is seen? I don't have the oil press. sensor hooked up right now and I think that might be what is bagging me.
    May 2008
    We have done a few looms without the oil pressure sender connected and they are fine... sounds like VATS in the software or injectors dont have 12v power... (possible wiring fault)
    E40's hate 'em
  1. Vortec 7.4, 0411 PCM, Standalone Harness...got a ?
    By Oxyacetylene in forum Vortec V6/V8 Specific
    Last Post: March 29th, 2016, 02:33 PM
  2. Cummins Standalone?
    By wickedcummins in forum Do you want to be a Beta Tester?
    Last Post: January 12th, 2012, 02:41 AM
  3. LS3 and 4L60E - What standalone ECM and TCM to use?
    By tunedportcj5 in forum Gen IV V8 Specific
    Last Post: April 16th, 2010, 12:24 AM
  4. Standalone flashing before SEMA?
    By Hyper99 in forum FlashScan V2
    Last Post: March 1st, 2009, 09:09 PM
  5. Standalone DVT?
    By Cougar281 in forum FlashScan V2 BB Logging
    Last Post: July 12th, 2008, 01:58 AM
