Results 11 to 20 of 40
Thread: What wideband do you use with EFI Live???
    Default Yup.
    Have you tried the newer firmware for the LM2?
    The way Innovate does business sucks.
    IIRC someone mentioning the AFR1200 with serial,
    ask Paul if it is or will be supported.
    Yup... Did that already.
    Chuck CoW
    Aug 2008
    I tried the new firmware also and I think it made it worse...
    What are we supposed to do with these paper weights if Innovative doesn't have an answer or solution. Damn!!! I tried all the sensor's(4 new one's and 2 that came with LM-2) on my LC-1 and they work just fine...LM-2 IS THE PROBLEM!!!!!!!!!....
    FLASHSCAN V2 & AUTOCAL
    I have had no problems with my LM1, sorry guys. The serial feature is important to me. I have seen the AFR fluctuate because of ground issues. Greg is the AFRecorder 1200 the $3500 meter that you referred to? ECM didn't have any pricing on their site.
    Thanks,
    Al
    Ive held off buying a WBO2 because everyone is complaining about Innovate's stuff really sucking right now.
    Im liking the Tech Edge WBO2 but Ive heard Greg and a few others speak highly of the NGK one, anyone have a place I can buy one from?
    Jun 2005
    www.google.com
    Think they're on eBay too.
    Default The LM1 worked ok....somewhat...
    The problem with it was that the power cord connection broke off the board 900 times or so...
    Requiring me to stop my work and open er' up to repair it over and over again.
    I do understand that the hobbyist or casual weekend tuner can have better results, but Innovate told me that this was a quality professional tool and quite simply, it's not working out that way.
    Chuck CoW
    Lifetime Member 98 tigershark's Avatar
    Nov 2006
    Default Does any one know of a shop that has success with innovative?
    Does anyone know if anyone has had success with innovative as a professional unit that tunes as many cars as Chuck does? As a enthusiast the LC1 works for me. I have seen some very high end professional WBO2 recently on some auction sites. Check out the auctions Chuck. Maybe you can get the one Greg \eficalibrator uses at a decent price. Did you say it does or odes not work with EFILive? That has to suck.
    Bt the way thanks for calling me back last month.
    regards,
    98 tigershark
    98 tigershark
    L92/427 w/L76 CC'ed heads n upgraded springs
    4.100 stroke, 4.068 bore w/ 11:1 comp
    Cam, 591 int, 613exhst, 232-246dur@.050, 115*
    LG headers, High flow cats,
    RPM level 5 trans, RPM 3.42 gears, 2800 rpm trq convrt. .
    Special Thanx to Joe and Bruce!
    Apr 2009
    Quote Originally Posted by 98 tigershark View Post
    I can assure you that the LambdaPro that I use works fine with EFILive, since I used it to tune my own C6 along with a few others so far. There is some question about ground loop noise, but I suspect that's partially dependent upon the quality of each unit's power supply and how many things you have in the loop. I saw no real offset when just using my Toughbook (w/12v cable), LPro, and EFILive.
    ~Greg
    Calibrated Success - EFI Training and Tuning Done Right
    GM Beginner's Guide DVD available now through Summit!
    Engine Management: Advanced Tuning - Amazon's best deal for the EFI crowd.
  9. #19
    Greg,
    Does the LambdaPro have the ability to output Lambda via serial comms...
    If it does, then Paul may be able to integrate it into V2 firmware.
  10. #20
    Nov 2006
    Default Now thats cool!
    A great question Joe!! If Paul can integrate it w/V2 that would be something.
    98 tigershark
    Greg,
    98 tigershark
  1. New to efi live / wideband question
    By Toby Van Horn in forum Gen III V8 Specific
    Last Post: November 22nd, 2009, 09:06 AM
  2. Please Help.. EFI Live-Adding Wideband PID
    By tatasta in forum Gen III V8 Specific
    Last Post: April 8th, 2009, 02:10 PM
  3. Which wideband are you using w/EFI Live?
    By TFZ_Z06 in forum Gen III V8 Specific
    Last Post: July 30th, 2008, 06:49 PM
  4. EFI live won't see wideband...???
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: July 15th, 2008, 03:37 AM
  5. wideband and efi live
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: May 25th, 2006, 04:28 PM
