Here it is, the first public beta release for the LBZ DSP upgrades.
Before proceeding please consider this, you will need to update your software and V2 firmware to beta versions, if you are using EFILive as part of your business and feel uncomfortable about doing this then perhaps wait until the software and DSP updates are classified as stable releases (probably 2 - 3 weeks).
The first step is you must update your software / firmware to the versions listed in the thread below.
http://forum.efilive.com/showthread.php?t=12014
Once you have updated your software and V2 firmware with the files in the thread above you can download the file attached to this post.
You can download the pdf document detailing the process to upgrade your ECM to DSP2 or DSP5 from THIS location:
This document should be saved in to the folder -
\Program Files\EFILive\V7.5\Doc\Tutorials
There is a zip archive attached to this post containing the necessary files for EFILive Tune to perform the DSP conversion. You must unzip these after installing the new software as it will overwrite the non DSP .calz files.
These files need to be extracted in to the folder -
\Program Files\EFILive\V7.5\Calibrations\E35
The document pretty much spells out what needs to be done so I won't cover that again in this thread.
If anybody strikes any problems with the DSP upgrade please don't do multiple post over multiple forums, it makes it very hard to track what is going on. You all know what Diesel forums we have a presence at, so post either on there or in this thread.
Work is well under way for the LMM DSP, we expect that will be in public beta in 2 - 3 weeks, just before we leave for SEMA.
Known issues with this Beta release:
- None reported so far
Enjoy!
