Thread: 2010 Camaro Firmer Shifts
    Oct 2009
    Question 2010 Camaro Firmer Shifts
    This is my first post so please be gentle. I have a 2010 Camaro with the L99 block and 6 speed auto. I've read many posts on the board concerning getting rid of torque managment, increasing shift pressures, and reducing shift times. I've attempted to make some of these basic changes in small increments, but have been unsuccessful in firming up the shifts. Could someone post a quick how to or at least tell me where to begin and what values are within safe limits.
    Thanks,
    Oct 2009
    Post My Current Adjustments
    So to help things along here are my current adjustments:
    Desired Shift Times
    D9005,D9035,D9065: Reduce to .3 from 4750 RPM - 6000+ RPM
    Shift Pressure - Pattern B Base Upshift
    D3030,D3033,D3036: Increase 10% on 1-2,2-3,3-4
    Torque Limits
    D9420: Increase 10% across gears 1-4
    Engine RPM Pressure Limiter
    Should I adjust D4004-D4007 ? up 10-15%?
    What else to firm up the shifts at WOT?
    Dec 2007
    Quote Originally Posted by mirage View Post
    Thanks,
    Where would you like to see improvements?
    If you log shift times, torque, rpm, vss, ETC then you will have a perspective on where you dont like it, and where you can focus your efforts.
    We leave TM on, reduce the base shift times a little, and mainly revise the torque/rpm shift time modifiers.
    Oct 2009
    Post
    I'm interested mainly in WOT. It just seems a little soft compared to my previous vehicle with a 4L60.
    All of my base shift times (D9000,D9030,D9060) are 0.000 I have not modified this from the stock program should these be reduced?
    In addition I will log some runs this afternoon to see where the car stands... Thanks..
    Dec 2007
    Hi mirage. Yes you are right, for '10 Camaros the base times were set at zero and a lot more weighting is on the torque based times. GM seems to have gone for a simpler strategy on the later years.
    You can try reducing these times (torque/rpm mod table D9005 etc) 10% at a time at the TQ/RPM area you are chasing, and consider increasing your pressure in the ~330ftlb column to match the top column. Do it seperately and then together to get the best feel for what makes the difference.
    Oct 2009
    Quote Originally Posted by gmh308 View Post
    Excellent this seems to have made a significant difference. I will continue tweaking in this area, but it is almost exactly where I want it now. Thanks for the help guys!
  1. camaro 2010 e-force
    By franckrem in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2010, 08:00 AM
  2. 2010 Camaro
    By jnjprfrmnc in forum E37, E38 & E67 PFI ECM's
    Last Post: October 29th, 2009, 08:06 AM
  3. 2010 camaro procharged
    By rubbersidedown in forum E37, E38 & E67 PFI ECM's
    Last Post: October 29th, 2009, 08:05 AM
  4. 2010 camaro issue
    By avb0119 in forum Gen IV V8 Specific
    Last Post: October 1st, 2009, 10:24 AM
  5. 2010 camaro
    By nchristian in forum E37, E38 & E67 PFI ECM's
    Last Post: June 15th, 2009, 10:03 AM
Tags for this Thread
