hahaa cool! i'll take 50 for 99 cents please!
465hp/1008tq---7/25/09---Dyno Day Fast SpecialtiesTuning by ME
I read that the 99 cent price is for orders of 200+, and is probably 99c each?
Andrew
EFILive Crew
okay i installed the switch just like the tutorial said, changed the OS and nothing happens when i click the switch.... it stays on my base tune and doesnt change...??? the switch i have is the one that came with my efilive so will that work for an lbz? oh and when i try and scan the volts on the switch my PIDS are not valid. i try vialidating the pids but no luck..any ideas are greatly appriciated
thanks
dillon
Mine didn't work either. Hopefully I get some time to play with it more.
2005/2007 DHRA Western Drag Champion
Bonneville A/DT & B/DT Land Speed Record Holder, 197mph best speed.
Casper - 05 GMC 2500 Dmax LLY 10.59 @ 129, 916rwhp
Big Blue - 04.5 GMC 3500SRW LLY 13.12 @ 104, 502rwhp sled puller
Wendy - 06 GMC 2500 LBZ 12.50 @ 107.5 First LBZ into the 12's. 542rwhp.
Blue Meanie - 02 Z06 11.40 @ 121 AFR H/C
There is another issue I need to play with as well. After the update, it would not recognize TCM tunes downloaded off Casper. So I just switched to my backup notebook with the latest release software, and it works fine.
EFILive does not supply DSP switches, your EFILive reseller must have supplied you with that.
When the scantool is connected, down in the bottom left corner of the screen is the VIN and OS number in the ECM, what does the OS number say?
Do I have to first download the newest efi update from the website and then download the zip file? or can I just unzip this file and install it with the version that came with software cd?
Yes, you must first be running the pre-release version, and then download and unzip the LBZ/LMM calibrations (beta).
Andrew
EFILive Crew
Okay thank you
