Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Anyone using serial output from FJO WB?
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Default Anyone using serial output from FJO WB?
    Been trying to get my EFIlive to work with the serial output from the FJO (GEN2). Can't get past "Controller Not Found" when programming the V2.
    Talked with a FJO tech person today. He said it will not work with EFIlive. Now I don't know who to believe. If anyone has FJO-serial working please let me know.
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
    Try this: swap the Tx and Rx wires in the FJO cable.
    Dec 2005
    I tried that today. Same result. I did get the pin location from the FJO tech for the Tx and Rx. My hook up was correct to start with.
    I pm'd Tech Support.
    Dec 2005
    Thanks. I really want to get a serial wideband working. If the FJO is not going to do the job for me which model no. of the Innovate do I need?
    Which FlashScan V2 firmware do you have...?
    Dec 2005
    Where do I find this?
    Which FJO unit do you have?
    FJO won't publish the serial protocol specs for the later FJO models.
    Still, we have "reverse engineered" the protocol for the late model units but I can't gaurantee that they will work.
    Also make sure you have the latest FlashScan firmware, V2.06.16
    Use EFILive Explorer to see what firmware your V2 has...
    Dec 2005
    It's a GenerationII FJO with the NTK sensor. It will be tomorrow before I can get the V2 firmware number.
  1. DSP Output changes
    By GMPX in forum Duramax LB7
    Last Post: November 12th, 2009, 01:43 PM
  2. E38 VSS output
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: June 29th, 2009, 07:14 PM
  3. What kind of serial output is used for V2?
    By Redline Motorsports in forum FlashScan V2
    Last Post: May 17th, 2009, 04:02 PM
  4. adapter to use LC-1 serial output
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: October 3rd, 2007, 10:59 AM
