Hello All,
At the moment I have a 12212156 w/2002 tune(silverado 5.3). I learned how to use cax files. It looks like LC is included in the PCM and build102. I don't think setting the tables worked. Do I need a cax? which one? I did find a collection that is just for LC enable. Says "go to b9000, set "enable", full flash PCM". Then tables will work.
Also, It appears that the transient fueling is also now included in build102. There are cax files for these too. The cax files have more TF tables. Is there any advantage to using the cax, can that even be done?
Gets kinda confusing. The evolution of the cax's are difficult for a noob to follow.
TIA,
S
PS, The brains behind this dev are over the top. I wish I had 1/10th of that capability.![]()
. With the new tune I gotta watch around town... it will burn more fuel if I use it. It is MUCH more fun to drive, is like a mild V8 truck should be... firm and more powerful.
