Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 61
Thread: Connecting LC1 to V2
    Nov 2005
    WO2ST is the wideband state (lambda = measuring, O2 = sees free air, error = bad), gives an indication of what the wideband is doing.
    I followed the instructions and installed the LC1 properly and calibrated it. The V2 is connected to the LC1 via the null adapter, and the V2 is connected to the E38. For some reason, the pids are not showing any activity.
    How can i troubleshot the problem?
    2002 Z28 HardTop M6 (408cid, F1C'd, 800rwhp+)
    2009 Z06 2L2 (Cammed 500rwhp+)
    Is the LC-1 powered up...?
    On the V2 go into the wideband display, does this show AFR/Lambda values...?
    In S&T Device Settings did you enable the serial/digital pids...?
    Post some log files.
    Nov 2005
    Im still trying to find the problem... I hooked the LC1 to a digital gauge and it showed readings in the 30's which means it is working, but maybe it is not calibrated properly. I thought the LC1 comes calibrated. I'm going to raise the scale in the A/F graph to 40 to see if i can see any movement. If that happens i will have to recalibrate the LC1 again i guess.
    Nov 2005
    Ok so far i checked all PIDs with serial connection and there is no activity on the scanner or the PC.
    Im going to try the analog route now to see if I can get some activity to the V2 software at the least.
    Nov 2005
    Good news... the analog readout works which means that the serial way didn't work for me.
    Now i have to find a way to change the reading from 0-1 and translate it to 7-22 A/F
    Nov 2005
    Good news... The analog route worked and it is showing me movement in the AD1 an average of .55 and a max reading of 1.09.
    Now i need to find a way to translate that into a custom PID so i can log it properly.
    Where in the v7.5 can i create a PID? Never done a custom PID before or even changes the value on one.
    Did you use a null modem adapter...?
    It has to specifically say "null modem" on it.
    See post #3: showthread.php?9340-serial-port-cable-that-goes-to-v2
    Did you enable serial wideband in the V2 setup options...?
  9. #19
    Nov 2005
    The adapter will allow two male serial ports to be merged. It has a sticker on stating "Mini Gender Changer" LMAO. It looks the same as pictured in the post you referenced.
    Also something interesting i noticed, when i went to the setting in the V2, i only found Port instead of Com In & Com out as pictured in the "Serial Wide band Tutorial". So i choose Wide-02 and Innovative, but it did not work.
  10. #20
    Quote Originally Posted by LSs1Power View Post
    A gender adapter is not sufficient... the null modem cable cross connects the Rx and Tx pins, like this:
  1. RR not connecting..need help
    By superspeed in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 29th, 2009, 12:50 PM
  2. Connecting LC-1's
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2009, 10:21 AM
  3. New help connecting to RR
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2007, 11:57 AM
  4. connecting lc1 to v2
    By mr.prick in forum FlashScan V2
    Last Post: February 8th, 2007, 01:46 PM
  5. LM-1 connecting to V1
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2007, 11:06 AM
