Originally Posted by
joecar
Howard,
Try this:
- connect the AFM to your PC's serial port using the null-modem adapter,
- go Start->All Programs->Accessories->Communications->Hyper Terminal,
- enter any name (AFM),
- click OK,
- enter any area code and phone number (111 2223333),
- set Connect Using to COM1 (or whatever your PC's COM port is),
- click OK,
- set 38400 baud, 8 Data Bits, Parity None, 1 Stop bit, Flow Control None (from the AFM manual),
- click OK,
- now you should be in the terminal window...
In the terminal window you should see stuff being printed... if not then remove the null-modem adapter.
If it still doesn't print, shutdown HyperTerm and restart it, this time specify the other COM port (e.g. COM3), and try again with and without the null-modem adapter.
