Yes thats my point exactly, the fuel trims will take the BEN to 0 every time. And thats what you are trying to do by massaging the VE table with an AFR BEN.
Hence the fuel trims that have been recorded are the exact adjustments needed to fueling to bring the BEN correction to 1.
I just wanted some more info about the cons/pros about using fuel trims for dialing in the VE compared to BENs in CL mode of course.
Weathermanshawn, can you explain why you've not had as much success applying fuel trims BENs to the VE table? I understand people saying its not as good as using AFR BENS, but being told is one thing, but to believe its true I need to be given a reason why AFR BENs are better to be used then fuel trims BENs as I can't see the difference in CL mode.
