Results 11 to 20 of 27
Thread: MAP sensor calibration
    Nov 2007
    What is the factory LMM MAP capable of reading ??
    Nov 2007
    Anybody know what the MAX pressure the stock MAP is capable of reading ??
    Feb 2007
    Should be 52ish PSIA.
    Nov 2007
    vs PSIG ??
    Jan 2008
    I would think that PSIA and PSIG would be the same in this case.
    Feb 2007
    Quote Originally Posted by L31Sleeper View Post
    vs PSIG ??
    Yes. The absolute highest reading is somewhere around 52, but that is including atmospheric pressure.
    Quote Originally Posted by bballer182 View Post
    Only if you are in space or somewhere else where there is a very high vacuum.
    I thought PSIA = PSIG + BARO
    anywhere where BARO is zero will allow PSIA to equal PSIG.
    Nov 2007
    So what do you do if you want to run 80 PSIG ??
  9. #19
    Feb 2007
    I'm not sure if this is directed at me or bballer, but a vacuum is a lack of atmospheric or barometric pressure.
    Get an aftermarket gauge. There have been a couple of people who have worked with replacement sensors that are good up to 100 PSIA and rescaling the sensor, but last I heard they were having problems with it. It was also on LB7 and LLY motors. I don't think LBZ and LMM motors have access to the boost sensor scaling in EFILive.
  10. #20
    Quote Originally Posted by JoshH View Post
    I was questioning bballer and affirming your reference to space (PSIA = PSIG = BARO = 0).
    PSIA and PSIG are generally defined to be related by PSIA = PSIG + BARO
    (nevermind me, I'm just sweeping thru all the threads)
    So has anyone explained why MAP isn't equal to BARO at sea level (I'm curious to know)...?
  1. E38 fuel level sensor calibration
    By harascho in forum E37, E38 & E67 PFI ECM's
    Last Post: November 29th, 2009, 03:39 PM
  2. AutoVE MAF sensor calibration
    By Ritch in forum Gen III V8 Specific
    Last Post: June 21st, 2007, 10:33 AM
  3. New pcv - knock sensor calibration?
    By voda1 in forum Gen III V8 Specific
    Last Post: June 1st, 2007, 08:42 AM
  4. Which MAP Sensor?
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2005, 09:01 AM
