How do you convert .tun or .ctd to .bin?![]()
LC-1 WBO2
Any luck 5.7ute?
FLASHSCAN V2 & AUTOCAL
You can use a different commercially/open source available editor and read the file from a bench PCM that you flashed with your proprietary format/different software tool... You can also go hardcore and yank the flash chip and read the image with a hardware programmer. If you do the latter, be sure to reverse the byte order in the binary if you want to be able to open it in the software editors.![]()
I ran across this problem years ago........trying to use a 5.7 pcm on a 4.3......I guess they (EFI Live) think
the risk of brickification is too high like on the E40
If the PCM is not affected by the cal only flash and does not work correctly as a V8, it is possible that it could be full flashed by a Tech2 and have all of the correct OS and segments written to it. This shouldn't require another license either.
Al
Everything went smooth with the cal only flash....Fired right up and owner has been driving vehicle for a couple of months now...
The OS's were actually the same "16263425" 4.3 cal only flash to 5.7
