I recently changed from an Innovate LC1 to a Zeitronix ZT-2 serial wideband controller. Since the change I've noticed some strange AFR's when the ZT-2 is plugged in using the serial cable to the flashscan V2. AFR readings seem to be off by a factor of 10. For example when the actual AFR is 14.5 the flashscan will show 1.45 during BBL. I think I have everything configured correctly, but I've got to be missing something simple. I have the following settings:
Com Port: Wideband
Wideband: Zt-2
Format: 1st wide band only
Data Display: AFR only
Do I need to create a calc PID or log a different pid for the ZT-2. I'm currently using EXT.WO2AFR1 same as I did for the LC1.
