Just a reminder, with a particular emphasis on WINE.
You can get the applications to run OK under WINE. I've had both Scan and Tune working to edit calibrations as save them again. What you can't do is talk to the V2 as the windows USB drivers will not interface with the Linux OS to give you access to the V2. The drivers need to be Linux native, not emulated as that is where the real hardware connection exists.
The thing is though, you don't always need access to the USB port. Now that BBL and BBR are working so well, you can read a log from the SD card under Linux, make changes to the calibrations using WINE and then write back to the SD card and flash the new tune using BBR. Sure it's not a "true" Linux application, but it does work quite well.
Simon.
