Results 1 to 7 of 7
Thread: GMH VTV6 '97 communication problem ? with info. i need help
    New Member southaussie's Avatar
    Mar 2011
    Unhappy GMH VTV6 '97 communication problem ? with info. i need help
    what am i doing wrong? i just got this cable off the net and it is in the diagnostic plug, and my lappy, and im running the efilive pro v4 registered, i have selected the gm-vt6 xml and chosen the correct com port whick has been assigned to the device and NOTHING...
    screen as follows
    31:33.642: Initialising...
    31:34.207: Opening COM4 8228,8,N,2
    31:34.469: Ready.
    31:39.002: Start macro: Engine data and DTCs: DATADTC
    31:39.000: Synchronising ALDL communications...
    31:39.000: Waiting for heartbeat: $08,$55,$A3
    31:39.000: Waiting for Aldl bus silence of at least 50ms...
    31:39.151: Com timeout: Expecting frame header byte
    31:39.163: Synchronising ALDL communications...
    31:39.163: Waiting for heartbeat: $08,$55,$A3
    31:39.163: Waiting for Aldl bus silence of at least 50ms...
    31:39.314: Com timeout: Expecting frame header byte
    31:39.325: Synchronising ALDL communications...
    31:39.325: Waiting for heartbeat: $08,$55,$A3
    31:39.325: Waiting for Aldl bus silence of at least 50ms...
    31:39.476: Com timeout: Expecting frame header byte
    31:39.489: Stop macro: Engine data and DTCs: DATADTC
    31:43.789: Check vehicle interface...
    31:43.794: Waiting for Aldl bus silence of at least 50ms...
    31:43.844: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    31:43.865: Max232 interface detected OK
    31:43.866: Scanning for heartbeat and chatter frames...
    31:43.866: Waiting for Aldl bus silence of at least 50ms...
    31:44.017: Com timeout: Expecting frame header byte
    31:44.032: No chatter found
    with i/o on
    10:30.102: Check vehicle interface...
    10:30.108: Waiting for Aldl bus silence of at least 50ms...
    10:30.158: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
    10:30.158: Start writing frame
    10:30.158: Send: $FF,$55,$AC
    10:30.159: Finished writing frame
    10:30.159: Wait 10 ms after writing, before reading...
    10:30.169: Start reading frame
    10:30.174: Aldl frame header byte: $FF
    10:30.174: Aldl frame length byte: $ 0
    10:30.174: Recv: $FF,$55,$AC
    10:30.174: Finished reading frame
    10:30.174: Max232 interface detected OK
    10:30.174: Scanning for heartbeat and chatter frames...
    10:30.174: Waiting for Aldl bus silence of at least 50ms...
    10:30.225: Start reading frame
    10:30.326: Com timeout: Expecting frame header byte
    10:30.384: No chatter found
    Oct 2004
    One thing that you could try, which has helped others with your error is lowering the Chatter T6 timing to 10 (often set to around 50). Let us know if that helps at all…
    Andrew
    EFILive Crew
    Mar 2011
    Angry
    done it and still doesnt work this is beyond a joke..
    Mar 2011
    this is what shows with usb view
    Device Descriptor:
    bcdUSB: 0x0110
    bDeviceClass: 0x00
    bDeviceSubClass: 0x00
    bDeviceProtocol: 0x00
    bMaxPacketSize0: 0x08 (8)
    idVendor: 0x0403 (Future Technology Devices International Limited)
    idProduct: 0x6001
    bcdDevice: 0x0400
    iManufacturer: 0x01
    iProduct: 0x02
    iSerialNumber: 0x03
    bNumConfigurations: 0x01
    ConnectionStatus: DeviceConnected
    Current Config Value: 0x01
    Device Bus Speed: Full
    Device Address: 0x01
    Open Pipes: 2
    Endpoint Descriptor:
    bEndpointAddress: 0x81 IN
    Transfer Type: Bulk
    wMaxPacketSize: 0x0040 (64)
    bInterval: 0x00
    bEndpointAddress: 0x02 OUT
    Transfer Type: Bulk
    bInterval: 0x00
    Oct 2004
    Quote Originally Posted by southaussie View Post
    31:34.469: Ready.
    Should be 1 stop bit.
    Andrew
    EFILive Crew
    Mar 2011
    Angry
    Yeah fixed the stop bit set to 1 now still the same result.
    No anything.
    Are you 100% positive that COM4 is the actual COM port that your ALDL cable is using?
    If COM4 happens to be your built in modem, then you may get those results.
    You should also check with the ALDL cable supplier whether or not you need to have MAX232 echo checked on or off in the Edit-Properties->Comms area. (Or just try it with that setting on and off to see if either setting works).
    Also for a VT V6 you should see chatter when you click on the "detect chatter" tool bar icon. If no chatter is detected then no data is getting from the ECM to the PC.
  1. Replies: 19
    Last Post: January 29th, 2009, 09:11 PM
  2. No Communication After Reflash?
    By Yukon 400 in forum Custom Operating Systems
    Last Post: October 22nd, 2008, 10:18 AM
  3. no communication w/ roadrunner...
    By rubbersidedown in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 4th, 2008, 12:42 AM
  4. Sometimes communication hangs
    By Ira in forum FlashScan V2 BB Logging
    Last Post: January 2nd, 2008, 09:29 AM
Tags for this Thread
