Page 1 of 8 123 ... LastLast
Results 1 to 10 of 74
Thread: Issues on the first day with efi live...
    Junior Member CIDRAUGHN's Avatar
    Mar 2011
    Default Issues on the first day with efi live...
    Ok, so i received my licenses, and the cummins tuning upgrade, and I have entered them in the appropriate places as per the instructions sent in the email from dans diesel performance. The issue is that once I open an efi live program, the windows on the computer will not close unless i unplug the V2 from the computer. As soon as I do, the windows close and everything functions properly. The other issue is that when I plug into the truck to try and read the factory calibration, it will connect, and say:
    Executing: C:\Program Files (x86)\EFILive\V8\Config\CMB_R.obj
    Virtual Machine Started
    Script Loaded
    Script Verified
    Reading...
    Checking Data File...
    Script exited with code $0311: Mode Not Supported ($11)
    I have updated the efi live both 7.5 build 164 and 8.2.1 build 155. Also I have updated the firmware to the most recent one. Any suggestions on what I should do? Help would be greatly appreciated.
    06 Dodge RCLB 2500 5.9L Hamilton, Maxxspool, Wicked Diesels, Bullseye Power, Industrial Injection, South Bend Clutch, Amsoil, K&N, ARP,EFILive, T&C Diesel, ATS, GDP...
    Can you please email me all the *.htx trace files from the folder \My Documents\EFILive\V8\Trace
    Send them to me at paul@efilive.com
    Include the URL at the top of this page in the email so I can correlate the email with this post.
    Lifetime Member FUBAR's Avatar
    Feb 2011
    My Scan Serial number is the same as his, so I'll be very interested in this topic before I try anything this evening when I get home.
    06 5.9L, EFILive / Silver Bullet Tuning
    06 LBZ, EFILive
    Mar 2011
    Email sent! Thanks for the fast reply.
    Jun 2011
    I was having the same problem. I exited the program, tried again and it read it. I'm having other problems, but I'll start another thread.
    Dec 2007
    same problem here
    getting "script file not supported" when i try to read the ECM
    emailing you the trace files as well
    Mar 2011
    Glad to hear its not just me. Also, I did try another truck, and it worked instantly on it. However, when I read the file and make the slightest change to it, it says that the values are out of range, and that efi live will not flash it. So now I have one truck that will do pretty much nothing but read the file, and another one that wont read at all. The scan tool does work partially, however, on both trucks.
    Jun 2011
    I just tried to shut off the post injection as a test and was able to save it. I don't think it will flash to my truck because it says "incomplete, do not flash".
    Oct 2004
    Quote Originally Posted by chizwizdiz View Post
    If you flash that file you will almost certainly get a no-start condition, which is why the warning is shown. The existing calibration is almost certainly a result of using another tuning tool previously. You will need to get a stock file before making changes and flashing.
    Andrew
    EFILive Crew
    Jun 2011
    Roger that. I uninstalled the previous tuner (as complete as I thought) but I still get that message. I didn't plan on flashing the tune I just modified, I was just curious to see if I could modify any tables, as well as save the file.
  1. New to EFI, and having Laptop issues
    By millerman04 in forum General
    Last Post: August 29th, 2010, 04:49 PM
  2. lc-1 serial to efi-live issues
    By Jakes4321 in forum General
    Last Post: January 25th, 2010, 11:15 AM
  3. Efi live class at efi university
    By Robbie The Wrench in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2008, 02:25 PM
  4. New to EFI Live
    By Whitetail Addict in forum Lounge
    Last Post: August 25th, 2008, 06:15 AM
  5. New to EFI Live and RR
    By wickedred in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 3rd, 2007, 04:28 AM
