Ok, so i received my licenses, and the cummins tuning upgrade, and I have entered them in the appropriate places as per the instructions sent in the email from dans diesel performance. The issue is that once I open an efi live program, the windows on the computer will not close unless i unplug the V2 from the computer. As soon as I do, the windows close and everything functions properly. The other issue is that when I plug into the truck to try and read the factory calibration, it will connect, and say:
Executing: C:\Program Files (x86)\EFILive\V8\Config\CMB_R.obj
Virtual Machine Started
Script Loaded
Script Verified
Reading...
Checking Data File...
Script exited with code $0311: Mode Not Supported ($11)
I have updated the efi live both 7.5 build 164 and 8.2.1 build 155. Also I have updated the firmware to the most recent one. Any suggestions on what I should do? Help would be greatly appreciated.
