but i have the newest software i believe... 8.2.1 Build 158 is what i have... can anyone help?
Works fine for me.
2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
Best 1/4 11.8 @ 118+ on #2 only
Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
Bobotune at rocketmail dot com
Makje sure your firmware is up to date on your V2
As Rob said make sure firmware is up to date. Start>Efilive>7.5>tools>check for updates
And
Start>Efilive>v8>tools>check for updates
Thanks guys, this solved the problem... i also hadda delete my V8 and redownload it from the website...
I have found that if I check for updates on the V8 it will not work. I have had to uninstall and then reinstall from the web site but do not check for updates
