Page 5 of 15 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 141
Thread: 06-07 5.9L Feature Request List
  1. #41
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    How about being able to run an injector kill test?
    This is what we use to figure out a bad injector (i.e. a bunch of white smoke or an erratic idle that isn't FCA related).
    Turn one injector off, turn it back on, turn the next off, etc.
    1207 HP / 1612 TQ
  2. #42
    Lifetime Member 06redram's Avatar
    Jan 2011
    Quote Originally Posted by DoghouseDiesel View Post
    I second that!! Injector kill test
  3. #43
    Jan 2011
    It would nice to be data long though V2 handheld to SD Card without laptop
  4. #44
    Dec 2009
    This may sound menial, but is there any way to get the OBDII cable with a 90* connector to the OBDII port?
    I know it may sound insignificant, but with the cable connected on the Dodges, the cable is directly between your legs and I notice myself hitting it every once in a while while logging.
    If we could get one, even buy it separately, that came out from the OBDII port and went toward the passenger side, that would be the cats meow.
    1207 HP / 1612 TQ
  5. #45
    Jan 2011
    Dm you r so right I have a clutch almost broke it off. A 90 would be great. I would buy
  6. #46
    How about being able to run an injector kill test?.
    Is this possible with the factory scantool?
    Quote Originally Posted by 06redram View Post
    Coming at some stage.
    I can see how that would be a pain. We can ask our cable supplier if they have right angle connectors.
    Someone might want to consider sending an Email to Multiplex Engineering, they do custom cables, all you would need is a R/A OBD-II plug to a OBD-II socket.
    http://www.multiplex-engineering.com/cables.htm
    Or you could move the OBD-II connector on the truck
  7. #47
  8. #48
    Dec 2009
    Yes it is. You can do it with both the StarScan and StarMobile.
    With the vehicle running, you can pick any individual injector and shut it down.
    The vehicle will stumble if the injector was working correctly.
    If the vehicle was smoking, running rough, sputtering, etc., when you shut down the bad injector(s), the condition stops and you know which one is the problem.
    It's really useful to isolate fuel delivery issues without having to remove and test each injector or cap off the port on the fuel rail.
    I would imagine it would be possible in the bidirectional mode.
    1207 HP / 1612 TQ
  9. #49
    Member Motorzane's Avatar
    Jun 2011
    It is also possible on Snap-On scan tools also
  10. #50
    Ok thanks, just needed to make sure the ECM was capable of doing that test. We sometimes get asked on GM vehicles for specific bi-directional tests, but unless GM programmed the ECM to have the ability then it can't happen.
  1. Feature Request List
    By skneeland in forum Cummins 5.9L
    Last Post: June 13th, 2011, 04:54 PM
  2. Feature request v2
    By ringram in forum General
    Last Post: July 9th, 2008, 04:44 PM
  3. Feature request
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: July 6th, 2007, 11:05 AM
