Thread: HHR (E37) 2010 FFV v. 2007 injector flow rates
    Jul 2011
    Default HHR (E37) 2010 FFV v. 2007 injector flow rates
    2007 HHR 2.2L running on a 2010 HHR FFV ECM (E37 with VVT disabled). Drove vehicle for several hundred highway miles over the weekend on both E85 and E10 and in both cases the DIC mileage reported is considerably lower than actual mileage measured. On E85 the DIC reported 18MPG, I measured 24. On E10 the DIC reported 20MPG, I measured 27.
    It is also throwing a DTC P0171 Fuel Trim System Lean code on both E85 and E10. (commanded AFR looks normal)
    Both of these "clues" would point me to look at a difference in injector flow rates...but both tune files have the same value (3.51 g/S if memory serves).
    I'm really more concerned about the mileage reading being so far off...is there some other parameter in the tune files that would effect this?
    It also seems to take an unusually long amount of cranking to start...if that is also a clue.
    Bill
    Jul 2011
    Ok apparently I have forgotten how to read! The 2010 tune file does indeed show a higher injector flow rate (B4001 Injector Flow Base) of 5.074 g/S as opposed to 3.51 g/S for the 2007.
    Guess it makes sense that a higher flow rate is needed to maintain RPM range for ethanol fuel.
    Bill
    Dec 2007
    Quote Originally Posted by MisterBill View Post
    Bill
    Fuel trim system lean means that the trims are topping out and it is still lean. Which is also a symptom of FF VFS not functioning quite right. Have you checked what ethanol content is being reported? GM did change the injector curves that were displayed in the later OS's once they moved to 16g/s injector limits for 09.
    Sounds like you need to Auto VVE it to get the VVE tables correct. If commanded AFR looks normal, whats the wideband say?
    You need to match the IFR table with the injectors, so if you're running stock 07 injectors then use the data from the 07 tune in the 10 ECM.
    Jul 2011
    Changing the injector flow rate to 3.51 g/S fixed these two problems.
    Thanks for letting us know.
  1. injector flow rates
    By GMMAD in forum Gen III V8 Specific
    Last Post: January 21st, 2011, 07:53 PM
  2. Injector Flow Rates
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 22nd, 2010, 07:22 AM
  3. injector flow rates
    By 02sierra4x4 in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 07:05 PM
  4. reprogram injector flow rates
    By sprouse99 in forum Tutorials
    Last Post: April 25th, 2009, 10:24 PM
  5. 44lb injector Flow rates?
    By lownslo in forum Gen III V8 Specific
    Last Post: April 14th, 2009, 02:01 AM
