Results 1 to 10 of 11
Thread: is it worth paying to upgrade v1 to v2 just for serial wideband input?
    Jun 2007
    Default is it worth paying to upgrade v1 to v2 just for serial wideband input?
    is it worth paying to upgrade v1 to v2 just for serial wideband input? I currently own v1 already and I am happy with it, but no serial wideband input
    9.8@150 . LQ4 Turbonetics Billet 7575@18psi, 6 speed, non-intercooled with meth. Speed Density, open loop, no PE.
    Nov 2006
    There are other features that make the upgrade "worth it".
    There was an End of Life (EOL) Notice on the V1 but that may have been canceled or extended.
    LC-1 WBO2
    Oct 2004
    The FlashScan V1 products are EOL now. They haven't been available for sale for quite some months now.
    Benefits of the V2 are:
    - You get an extra couple of VINS so the actual cost is really low.
    - Serial wideband support.
    - All the stand alone capabilities of the FlashScan v2 device.
    - Supported in the V8 software.
    Andrew
    EFILive Crew
    Not needing to lug a laptop all the time for reading and writing, serial input is icing on the cake!
    Al
    Ryan,
    - how often do you log (V1 can do BBL, but you can't view data while BBL'ing since it has no LCD)...?
    - how often do you flash...?
    - do you have any problems at the moment with the analog wideband connection...?
    Jun 2007
    Ryan,
    If I want to view data, id just prefer use the laptop because the screen is so much bigger and allows me to look at data quicker and keep my eyes on the road.
    I flash quite a bit because I'm always changing my car's setup. Is v2 quicker at flashing?
    My aem wideband has some lean spikes that i can't explain so I'm going to throw an innovate in there along with the aem to verify.
    I guess my real question was is the serial connection that much better then analog?????
    V2 takes same amount of time to flash an LS1 PCM as does the V7 tunetool.
    The advantage of V2 is you can flash and log without needing the laptop in the car... however, V2 is still undergoing development so you will be updating firmware every few weeks ( for some people this is a bit tedious... but for others (me) this is to live for )
    The serial connection avoids ground offset problems, this is handy if you're being plagued by these.
    Jun 2007
    so am I going to run into any issues with v1 being EOL ?? Or any issues selling it? I believe it came with two pcm's licenses and I've only used one. So i was thining about selling it along with the one unused license.
    Oct 2004
    Quote Originally Posted by ryans1000 View Post
    When upgrading to FlashScan V2 you need to be aware of a couple of things, which are important considerations if anticipating selling the device:
    1) The new owner of the FlashScan V1 is not able to upgrade themselves to FlashScan V2. The discounted offer is available only once per FlashScan V1, and you will have used that right for your upgrade.
    2) No further PCM licenses will be issued to the FlashScan v1 device. So if you want to sell the FlashScan V1 it will need to have at east 1 available PCM licenses on the device. During the upgrade (license copy/move) from FlashScan V1 -> V2 you will not be able to move unused licenses, as that would leave 0 on the V1.
    You need to notify the potential owner of both these constraints if they are considering purchasing your FlashScan V1 device.
    The FlashScan V1 -> V2 upgrade product can be purchased from EFILive direct, or some resellers may also have stock.
    Andrew
    EFILive Crew
    Jun 2007
    ok, so after the upgrade, my v1 will still have its one extra license right. And also the v1 would always be good for unlimited 97/98 ls1 tunes right?
  1. Replies: 50
    Last Post: March 15th, 2009, 04:00 PM
  2. New problem with V2 serial wideband input
    By thunder550 in forum FlashScan V2 BB Logging
    Last Post: June 4th, 2008, 03:02 PM
  3. Worth the upgrade?
    By zapp168 in forum FlashScan V2
    Last Post: May 14th, 2008, 09:20 AM
  4. Upgrade to 7.5.1 worth it for LS1?
    By RevGTO in forum Gen III V8 Specific
    Last Post: October 10th, 2007, 12:57 PM
