Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 80
Thread: Release Candidate 8, Jan 06, 2012
    Lifetime Member FUBAR's Avatar
    Feb 2011
    Are these (which ones if so) that I need to manually "program?"
    -Thanks
Name:	efi explorer pic.JPG
Name:	efi exlorer2.JPG
Name:	efi explorer 3.JPG
    06 5.9L, EFILive / Silver Bullet Tuning
    06 LBZ, EFILive
    Feb 2011
    OK, you beat me to it! Thanks man. The date did revise to Jan 6. I programmed the FSProg file, but should I do anything with the ACProg file in the same folder? And both of my ACBoot and FSBoot BootBlock files are dated 12/19/11 so that means I probably should do anything with since they were created before RC7 and RC8?
    06 LBZ, EFILive
    I dont know if you need to update the bootblock, so in the 3rd pic click the FSBootV2_07_04.efw, click Open. Now make sure you check the BootBlock checkbox in the firmware tab! Program it in, then once your V2 is in deadpoll, click Browse again and select FSV2_07_22fw.efw on the 2nd pic you posted. Click Open, now uncheck the BootBlock checkbox! and click Program. Should be set.
    Feb 2011
    Thanks again man! Everything worked! Something I didn't know...one more EFI wrinkle to add to the 'ol noggin.
    06 LBZ, EFILive
    If the versions are the same but the dates are newer, then program in the newer ones.
    Quote Originally Posted by vortecfcar View Post
    Thanks for your hard work guys!
    No worries Nick, I know you are going to appreciate the Cummins VIN change directly in the tune tool, that's saved you about 20 mins work for AutoCal tunes.
    Feb 2011
    [*]Fixed CMB checksum issue caused by "box tuners" not returning controllers to stock (please refer to new pdf guide for more info).
    I could not find this in the help section in the TuneTool. I also looked in the "Documentation/Tutorials" section on the main web site as well. Not sure where else to look.
    -Thanks
    06 LBZ, EFILive
    Jun 2011
    I installed the release 7 at the end of December on mine, do I still have to uninstall both v7 and v8 to install this new update, or am I good with having done it for the last update?
    Thanks!
    06 CC DRW, DTT, EFI Live.
    473HP
  9. #19
    Quote Originally Posted by FUBAR View Post
    Like I have to keep telling my kids, 'go have a better look', just joking .
    If you open EFILive Scan and Tune (V8), then go to the menu item 'Help' >> 'Documents' , it's the first one listed.
    Quote Originally Posted by mstordahl View Post
    If you have been installing the Release Candidates then you can just install over the top of what you have.
  10. #20
    Feb 2011
    Hardy..har..har..lol.
    Guess I should've...I was too busy looking in V7.
    06 LBZ, EFILive
  1. Release Candidate 7, Dec 22, 2011
    Last Post: January 4th, 2012, 07:12 PM
  2. Release Candidate 2, Aug 19, 2011
    Last Post: September 13th, 2011, 09:58 AM
  3. Release Candidate 1, Aug 04, 2011
    Last Post: September 11th, 2011, 03:36 AM
  4. March 05, 2011 release candidate 2
    Last Post: March 20th, 2011, 02:36 PM
