Results 1 to 5 of 5
Thread: reluctor wheels?
    Jul 2009
    Question reluctor wheels?
    for the ls1a and ls1b ecm what will be the correct tooth count for those ecm to recognize or will it matter? i have both 24x and 58x stroker cranks and would like to know the correct wheel to use before assembly the computer os is 7603,2004 year model if that helps.... also any other information i should be aware of including years fo particular crank triggers, or maybe a simple answer as in it doesnt matter...
    thanks in advance,
    Benjamin
    2004 joe gibbs, rcsb, t-56 6 speed, 4.8l supercharged 10#, cam, bolt-ons, etc
    1987 gnx
    d-21 allis chalmers 3000 hp 504ci on alcohol
    2004 dmax tow pig
    Aug 2010
    Gen III = 24x CKP
    Regards,
    Taz
    Jul 2009
    Quote Originally Posted by Taz View Post
    Gen III = 24x CKP
    Regards,
    Taz
    thanks for the reply, so with being nosey whats the 58x for?
    1987 gnx
    2004 dmax tow pig
    Aug 2010
    Quote Originally Posted by relentless addiction View Post
    ... whats the 58x for? ...
    Gen IV = 58x CKP
    Regards,
    Taz
    Yep, Taz nailed it. The Gen III PCM doesnt recognize the 58x reluctor unless you run a converter box (I only know of the one from LPE). The E40 is the odd one out, officially its a Gen IV ECM but only works with 24x reluctors. E38/39/67/etc are all 58x.
    I dont know why GM made the change, imagine it has something to do with the newer ECMs having faster processors so they can actually take advantage of the higher resolution. Better emissions probably also plays a part somehow.
  1. Replies: 83
    Last Post: September 26th, 2015, 02:18 PM
  2. 4x Reluctor
    By doubledip in forum General (Petrol, Gas, Ethanol)
    Last Post: September 10th, 2010, 02:55 AM
  3. 58 tooth reluctor
    By v8vegaman in forum Gen IV V8 Specific
    Last Post: January 10th, 2008, 05:38 PM
  4. 24>58 reluctor hack??
    Last Post: March 14th, 2006, 02:45 PM
Tags for this Thread
