Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 82
Thread: Chev/Holden 1.4L Cruze E85 FlexFuel Conversion
  1. #31
    Quote Originally Posted by Boost View Post
    please tell me the Verano T will be EFILive friendly
    Are they out yet?
    I would bet it's using the E39 ECM, so yes it'll be EFILive friendly.
  2. #32
    Dec 2006
    Yes!!!
    $2800 '02 Silverado RCSB 5.3 L59
    daily driver
    $3600 '05 Savana G3500 box truck 6.0 LQ4
    sleeper race truck project
  3. #33
    Dec 2007
    Well the Verano T has the same general engine (LHU) as in the Solstice/SKY Turbo models (LNF) and the ECU is Bosch for the Solstice/SKY.
    But EFILive supports it in the Regal GS that uses the LHU so does that mean that it's supported?
    Grrrrr... I was planning on purchasing a new car this weekend.. Will it be a Cruze, Regal GS, or 328i? Now we can consider the Verano T... grrrr... decisions decisions..
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
  4. #34
    Bosch ECM's are history with the GM SIDI engines now, everything has switched to the E39.
    I don't know what the Verano T looks like, but if I had all those as an option I'd probably take the Regal. The Cruze is a good car, but it's a little bit too small.
  5. #35
    Dec 2006
    The Verano is a Cruze, with some nice Buick touches and big engines.
    daily driver
  6. #36
    You guys have all the choices
  7. #37
    Dec 2006
    I am having a strange issue with logging the Cruze. When I try to log any other PIDe than the same ones I always have in my shared logs, I get an error. This includes even validated E78 PIDs. If I add just one new parameter (for example, Current Gear or Octane Scaler) it won't work at all.
    daily driver
  8. #38
    Jan 2011
    Keep your total number PID channels below 24 and it should be fine (try removing 1 or 2 PIDs and try it again). I have not asked Ross about this, but it seems like we are limited to 23-24 PIDs max, even when using Dynamic mode.
  9. #39
    Are you using a laptop or the V2?
    My laptop has never even been in the Cruze, I just use the V2 (for logging and flashing). The V2 will log more PID's and faster than V7.5 pass through.
    On the V2 I have 42 channels on the ECM and 22 on the TCM, but I think I'm going to drop the TCM from my logs for some extra speed.
  10. #40
    Jan 2011
    The 24 channel limit is with the pass through.
  1. 05 Hummer/55 Chev conversion..
    By Chuck L. in forum Conversions / Aftermarket Parts
    Last Post: June 8th, 2011, 03:45 AM
  2. E85 Conversion
    By duramax2500hd in forum Petrol / Gas
    Last Post: June 15th, 2010, 01:12 PM
  3. L92/L76 AFM/FlexFuel
    By Cougar281 in forum Gen IV V8 Specific
    Last Post: April 21st, 2009, 10:38 AM
  4. L98 into LS1 Holden conversion
    By rally1 in forum Gen IV V8 Specific
    Last Post: September 10th, 2008, 01:58 AM
  5. Flexfuel - E85 - How does the ECM know?
    By gmh308 in forum Gen IV V8 Specific
    Last Post: February 16th, 2008, 03:59 PM
Tags for this Thread
