Results 1 to 9 of 9
Thread: Boot loader rejected
    Default Boot loader rejected
    I was attempting to read the tune off a friends truck at the track tonight to check the shift points and was gonna check the AFR commanded in the tune.
    Its an 2004 silverado. The pcm was tuned with efi live but not sure if it was locked or what.
    So when i tried reading it, i got this error.
    Then i pulled the radio fuse and tried it again since it had a aftermarket head unit. Same error.
    Its been a couple years since ive ran into a problem like this. Dunno where to start.
    Jonathon,
    I take it you have V7 build 211...?
    Do you see this on other PCM's...?
    Ill have to check.. i havent done an update since about feburary 2012..
    This is the only time i seen this error.
    Ive done a few 2000 and a few 2002 LS1B pcms along with a 2003 and a 2004.
    This one is giving me the error.
    Check the lock status. Does it have an alarm or anything else that may be messing with it?
    Quote Originally Posted by minytrker View Post
    Im gonna have to look for the lock status.. never dealt with it before.
    Where do i find the lock status?
    I would suggest something aftermarket on the data bus causing issues.
    Is there another fuse i can try? or do i just need to do a bench flash setup?
    You really do need V7 build 211 and firmware 2.07.35 (obtained via V8 build 203).
  1. boot loader problem
    By skyhighsami in forum Diesel
    Last Post: July 7th, 2010, 06:50 PM
  2. bootloader rejected
    By relentless addiction in forum Duramax LLY
    Last Post: May 25th, 2010, 07:26 PM
  3. Bootloader rejected
    By lilly in forum Duramax LLY
    Last Post: June 28th, 2009, 02:48 AM
  4. Bootloader Rejected
    By KWSUNDELL in forum Duramax LLY
    Last Post: October 21st, 2007, 08:32 PM
  5. Boot Loader Error
    By dlandsvZ28 in forum FlashScan V1
    Last Post: June 24th, 2007, 02:32 AM
